Help! Is this guy correct? - JeepForum.com
post #1 of 16 Old 05-23-2013, 12:54 PM Thread Starter
da8
So, I was considering buying a 96 jeep grand cherokee to basically use it for the front end and some misc. parts. I have a 98 5.2 V8 Grand Cherokee. His is a 96 4.0 V6. I was told on the forum that I needed 3.73 gears a Dana 44. Start at the bottom and read up. Is he correct?
Him
Yup. The Dana 44 is just a little more heavy duty. These will work fine for regular driving
Me
So they have 3.73 gears in it? I was told I need a Danna 44? I have a 98 V8 5.2.
Him
Those will work with your gears
Me
Thanks for the info. Unfortunately, that will not work for me I have 3.73 gears in it,
Thanks
Him
The rear is a Dana 35,
front is a Dana 30,
4.0 motor with 168xxx miles,
da8 is offline
post #2 of 16 Old 05-23-2013, 12:58 PM
sjones26573
No such thing as a 4.0 V6 Jeep.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #3 of 16 Old 05-23-2013, 01:09 PM
ZJNewbi3
THANK YOU! It angers me when I see craigslists posts that say "has 4.0L V6"
ZJNewbi3 is offline
post #4 of 16 Old 05-23-2013, 01:14 PM
SCZJ
1994 ZJ
Are you asking if it's okay to swap the front axle from his jeep to yours? As long as the metal tabs on all axles involved say "3.73" you should be good to go.
'94 ZJ, 4.0, D30/D44A, 4 1/2" lift, 32" tires, 3.73 gears, etc... Just another cookie cutter ZJ.
SCZJ is offline
post #5 of 16 Old 05-23-2013, 01:25 PM Thread Starter
da8
Yes, I was under the impression it had to be a V8 in order to have those gears in them not a V6. All I want to do is swap the front end
da8 is offline
post #6 of 16 Old 05-23-2013, 01:46 PM
ROFLwaffles
Stop saying V6. It's an I6.
ROFLwaffles is offline
post #7 of 16 Old 05-23-2013, 02:05 PM
dnuccio
it might not have the right gears. you need 3.73 gears. the 4.0 had 3.55 gears unless it came with factory trailer prep or trailer tow, in which case it wouldve had 3.73s
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 16 Old 05-23-2013, 02:06 PM
BoostinChick
My I6 rear D35 has 3.55's in it. As long as the gearing matches up which you can confirm on the tag itself. I personally wouldn't go from a D44 to a D35 unless you are going to build it/lock it.
1998 Jeep Grand Cherokee 5.9L
BoostinChick is offline
post #9 of 16 Old 05-23-2013, 02:09 PM
dnuccio
35 isnt even worth it to build and lock lol
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 16 Old 05-23-2013, 02:12 PM
BoostinChick
A lot more aftermarket support on a D35 vs. a D44
F'it save up your money and just go with an 8.8 rear.
post #11 of 16 Old 05-23-2013, 02:21 PM
tucsonzj
^this
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #12 of 16 Old 05-23-2013, 02:59 PM
dnuccio
Originally Posted by tucsonzj View Post
^this
x2
R.I.P. Ratmonkey
dnuccio is offline
post #13 of 16 Old 05-23-2013, 03:00 PM
KingtheZJ
OP, whats your end goal?
yes, you could put the 3.55 D30/D35 in and drive it on the road. it will be slower and the rear axle will be weaker
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #14 of 16 Old 05-23-2013, 03:52 PM
kensnelling
Well, your post is a little confusing. You start out talking about the front differential, which from the factory is a Dana 30 on all ZJ's, then start talking Dana 44's, which is a rear differential. If it is the front differential then his will work just fine as long as it has the same gearing and pinion flange as your ZJ has.
Ken
kensnelling is offline
post #15 of 16 Old 05-23-2013, 04:17 PM
PolkaPower
This whole idea is a bad one from the start. Don't bother swapping stuff from a I6 to the V8. The d44a is a much stronger rear axle. Unless you can be sure that front D30 in the I6 has 3:73 don't even worry about it. I would look for a 96+ V8 donor to start with in the first place.
PolkaPower is online now
