Help with the gears in my dana 30 - JeepForum.com
post #1 of 7 Old 11-02-2010, 09:36 PM Thread Starter
KrazyKat1313
1990 XJ Cherokee
So I am regearing my front dana 30 axle from 3:07 gears to 4:11....through my research found out that I needed a carrier from one with with 3:73 gears or bigger and that they were in grand cherokees with the v8 and tow package
Now for my question....why are the gears that were on the carrier I got, which came out of a 96', standard rotation and not reverse cut like on the cherokees????
KrazyKat1313 is offline
post #2 of 7 Old 11-02-2010, 09:38 PM
CatSplat
1994 ZJ
Because Cherokees used a High Pinion front axle, while Grand Cherokees used a Low Pinion.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #3 of 7 Old 11-02-2010, 09:41 PM
freakinheep89
Catsplat's right, the HP30 from the XJs uses reverse cut gears. you will have to get the 3.73 carrier and get a new reverse cut R&P
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #4 of 7 Old 11-02-2010, 09:41 PM Thread Starter
KrazyKat1313
1990 XJ Cherokee
Did all grand cherokees use a low pinion?
post #5 of 7 Old 11-02-2010, 09:41 PM
freakinheep89
yes
TJ-
post #6 of 7 Old 11-02-2010, 09:54 PM Thread Starter
KrazyKat1313
1990 XJ Cherokee
K, thanks for the help I feel much better now knowing that I ordered the right gears for my cherokee....it worried me when I compared them to the one out of the grand cherokee and they were opposite
post #7 of 7 Old 11-02-2010, 09:58 PM
freakinheep89
yep, the HP30 turns on the stronger side of the gear, thus the reverse cut. and also the reason why ZJ owners consider it an upgrade to swap in an HP30. im due for one shortly because one of my axle nuts un torqued itself somehow and messed up the bearings.
TJ-
dana 30 , gear cut , gears
dana 35 gears nick3209 ZJ Grand Cherokee Forum 2 05-13-2009 08:58 PM
Changing open Dana 30 3.55 to 4.10 gears gabrod72 ZJ Grand Cherokee Forum 6 04-14-2008 11:01 AM
rear axle gears on a 2002 dana 44 destroyed!!! eltigrekid ZJ Grand Cherokee Forum 9 01-25-2008 04:51 AM
Dana 50TTB / Dana 60 Rear Questions Wulfman ZJ Grand Cherokee Forum 2 08-26-2006 09:40 AM
WTF! No gears for the 5.9L(dana 44A) gdupjeep ZJ Grand Cherokee Forum 12 12-25-2005 03:27 PM
