Quantcast Help GC 99 cranks but won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Help GC 99 cranks but won't start
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 11-08-2008, 11:58 AM   #1
fazza
Hi Looking for a bit of help.
bought a 1999 GC ltd 4.7 with LPG conversion, drove fine for a number of days then just started with this problem.
starts ok drive to where I'm going park up, return to car won't start just cranks. this could go on for anywhere between 5 mins and 3 hours try again and works. today called breakdown took them 3 hour to get to me (thats another story) kept trying to start every 10 to 20 mins or so nothing.
recovery come load it up get it to garage open door to steer of low loader start up straight away.
Help I'm now going bald
fazza is offline   Reply With Quote
Old 11-10-2008, 12:29 PM   #2
fazza
26 veiws but no replies so I take it no-one can help then?
Old 11-10-2008, 01:00 PM   #3
swataz
REALLY a shot in the dark, but trust me it is relevant - do you have a Mobil Speedpass on your keychain?
Oops, my bad. if I am not mistaken, there are only Esso stations where you are...not sure if they offer the speedpass payment option in the UK anyway. Like I said - shot in the dark.
swataz is offline   Reply With Quote
Old 11-10-2008, 01:18 PM   #4
windsors03cobra
Start with checking for spark during a no start event, you need to figure out if you have a spark or fuel problem.
I have seen LPG regulators do real funny stuff as they get older and contaminated during use.
If you have spark but no start you have fuel woes. if you dont have spark you most likely have fuel.
windsors03cobra is offline   Reply With Quote
Old 11-10-2008, 02:30 PM   #5
fazza
thanks for replies.
no speedpass, even tried switching off bluetooth as told this sometimes interferes.
Old 11-10-2008, 02:34 PM   #6
fazza
thanks fueling fine or smell of fuel when cranking,
Old 11-10-2008, 02:51 PM   #7
-Joe-
Check for any stored CEL codes..
Retrieving codes:
Turn the ignition key until the digital odometer displays, repeat three times in succession and then back to "On" (On/Off, On/Off, On/Off, On). At the fourth "On" the odometer will be replaced with codes. If no codes are present then "Done" will appear.
Codes are listed here : http://www.wjjeeps.com/faultcodes.htm
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Glock Forum
