Help Front End Swap - JeepForum.com
post #1 of 3 Old 05-16-2013, 03:45 PM Thread Starter
da8
Help Front End Swap
I have a 98 Jeep grand Cherokee with a 5.2 V8. The front end has 3.73 gears. Can I use the front end from a 94 jeep grand cherokee with a V6 engine? I need the entire front end swapped out.
Thanks
da8 is offline
post #2 of 3 Old 05-16-2013, 03:58 PM
tucsonzj
depends on the gearing. Needs to match yours. Several factors here, including t-case.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #3 of 3 Old 05-16-2013, 05:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
you're best sticking with 96-98 v8 or i6 with tow package. but best to stick to the v8.
the early ones(93-95) have a longer pinion and will make your drive shaft too long to fit back in.
ratmonkey is offline
