Help Front end - JeepForum.com
post #1 of 11 Old 05-14-2013, 04:29 PM Thread Starter
da8
Help Front end
I have a 98 jeep grnd cherokee 5.2 v8 all wheel drive. My front end went out. I have a few options. Can I use a 95 grand cherokee front end? Can I use a 96 front end? I can buy either of those for $150. Or a whole 98 grand cherokee limited for 700. What do you think and can I use the 95 or 96? Also all of them have about 180,000 miles on them.
Thanks
da8 is offline
post #2 of 11 Old 05-14-2013, 04:38 PM
tucsonzj
buy the 98. Use what you need, then it's a straight swap. Sell it off for parts and make your money back and then some probably. JMHO
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #3 of 11 Old 05-14-2013, 05:24 PM
BuzzZJ9er
This^^^^
BuzzZJ9er is offline
post #4 of 11 Old 05-14-2013, 05:42 PM
paintballwannab
Biggest thing is gear ratio, with the v8 you have 3.73 gears. Meaning your replacement axle needs to be out of a v8 grand cherokee. 4.0 had 3.55 gears, the axle is a direct swap but will need to be re-geared.
Providing the 98 is a v8 that's your best option, gets your axle and a bunch of other parts all in one shot.
paintballwannab is offline
post #5 of 11 Old 05-14-2013, 05:55 PM
BuzzZJ9er
If you buy the 98 feel free to ship the drivers door up north. Lol
post #6 of 11 Old 05-14-2013, 05:56 PM
tucsonzj
IIRC not all v8s came with 3.73s.
tucsonzj is offline
post #7 of 11 Old 05-14-2013, 06:00 PM
paintballwannab
I thought I read that they did...but very well could wrong. As long as it hasn't been removed there should be a tag on the front diff showing what gear ratio it has, so it can be matched with the new axle.
BTW the OP never actually said axle, motor, etc. I just assumed he was referring to a axle?
post #8 of 11 Old 05-14-2013, 06:04 PM
tucsonzj
I first assumed motor...maybe he should specify.
I know in 93-95 the v8's came with either 3.55's or 3.73's.
tucsonzj is offline
post #9 of 11 Old 05-14-2013, 06:14 PM
dnuccio
yep, saw a 93 v8 in the junkyard with 3.55s when i was looking for a new axle. couldnt believe it lol
also 4.0s with the factory trailer prep or trailer tow package wouldve came with 3.73s
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 11 Old 05-14-2013, 06:34 PM
tucsonzj
same for v8's. tow package always has 3.73's. what I have
tucsonzj is offline
post #11 of 11 Old 05-14-2013, 07:07 PM
1skrewsloose
This sounds right, my 4.0 with tow package has 3.73. 98 GC
1skrewsloose is offline
