HELP!!! Electrical seats stop working!!! - JeepForum.com
post #1 of 9 Old 04-08-2009, 06:45 AM Thread Starter
joffett
I have a 1993 Grand Cherokee (ZJ), with electrical seats. For some reason the passenger seat has stop moving back, but will move forward. My seat is all the way up now due to my mother not listening to me when I told her do not move the seat, but she did anyway. Is there a way to override the electric seat manually by moving it back? If so please let me know, I’ve goggled this topic and found no solutions, as of yet.
Thanks.
joffett is offline
post #2 of 9 Old 04-08-2009, 09:04 AM
wj_jeep92
no clue as to what it could be (sorry) however if u figure it out please pm me and tell me the problem. my driver side power seat in my wj has issues. its the five way adjustable seat and is stuck with the front of the seat all the way up. very irritating. i ridearound lookin like a thug.
1998 ZJ 5.9L
wj_jeep92 is offline
post #3 of 9 Old 04-08-2009, 09:16 AM Thread Starter
joffett
Im not sure what it would be, I'm thinking about replacing the fuse, but my driver side seat works fine... and on the passenger seat it will not move back, but it will move forward, up and down. Not sure what is going on....
joffett is offline
post #4 of 9 Old 04-08-2009, 10:21 AM
ducttapeman90
It's more than likely a problem with the track causing too much resistance to allow the seat to move back. My passenger seat had similar problems where the motor would only move about an inch in each direction. I pulled the seat out and cleaned up the track, went to put the seat back into the Jeep, and ... it wouldn't fit in - somehow, the seat track got misaligned and one of the tracks was farther up than the other one. To fix that, I removed the torx screw that holds the track onto the worm gear mechanism and I on one of the two tracks I was able to move it forward to line up with the other. Then I just reassembled it (be careful when putting that torx screw back in, it goes into plastic and you can easily strip it out) and the seat fit back into the Jeep with no problem, and the seat would actually move too!
"Who needs a girlfriend when you have a jeep!" -my ex
ducttapeman90 is offline
post #5 of 9 Old 04-08-2009, 10:59 AM
Mickey_D
It sounds like the contacts on the "move back" portion of the switch have failed. Something you could do is unplug the connector to the motor underneath the passenger's seat and figure out what pins make the seat move forward. Then jumper it reverse polarity. That's all the switch does.
Oh, and once you get the seat moved back? Unplug the main connector under that seat...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #6 of 9 Old 04-08-2009, 11:41 AM Thread Starter
joffett
I will try that..., but for now is there a way to move it back manually?
joffett is offline
post #7 of 9 Old 04-08-2009, 04:08 PM Thread Starter
joffett
Thanks for all your help guys..
It came down that I need a new seat switch. The switch is not making the copper ends connect. I end up taking it apart and putting it back on without the switch connected the copper ends together and the seat moved any direction I wanted it to.
The question is what is that switch called exactly called, and how can I find one for a 1993 grand Cherokee. I looked on jeep4x4center couldn't find anything... Is there any other place you know that carries parts...
joffett is offline
post #8 of 9 Old 04-08-2009, 04:32 PM
Mickey_D
Junkyard???
________________
#4
Mickey_D is offline
post #9 of 9 Old 04-08-2009, 07:20 PM
blackjack12982
1994 ZJ
Mickey got to it before I did. Mine did the same thing before it went into the shop, but today when I got it back I swapped out the control switches (took like 5 minutes) they are all functioning. With the price for this being like $5, I would check this before doing too much. I pulled mine from a 93 ZJ, so evidently the switches are year specific. So, definitely check out your local junkyards.
blackjack12982 is offline
Stereo causes all gauges to stop working gstouffer ZJ Grand Cherokee Forum 10 01-29-2010 01:05 AM
06 XK front A/C stop working!! uwnt1moore WK Grand Cherokee & XK Commander Forum 4 07-31-2009 12:55 PM
ESP stop Working on 2006 WK romerogz WK Grand Cherokee & XK Commander Forum 0 05-28-2009 08:18 AM
windshield wiper stop working ttavenieriii ZJ Grand Cherokee Forum 0 04-06-2009 01:02 PM
Stop lights stop working on 2002 Larado dhands ZJ Grand Cherokee Forum 1 08-28-2006 10:35 AM
