Help with ECM - JeepForum.com
post #1 of 2 Old 02-04-2013, 06:29 AM Thread Starter
Dre40
Help with ECM
Does any one have a schematic of the three connectors on the ECM? the Gray White and Black? My problem is the jeep wont start sometime or just dies while driving. If I wiggle the Black Connector it starts and runs fine, if I wiggle it again it dies. Would you think the problem is in the ECM or the black Connector? The only thing I noticed when I got the donor connector from the JK the two little tabs you squeeze are missing on the one in the jeep. Oh this is a 97 ZJ.
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #2 of 2 Old 02-04-2013, 06:37 AM
melk
Chances are the ECM itself is ok, it's just the loose connector that's causing problems. Hit it with some spray electronics cleaner and then snug it down with a zip tie
melk is offline
