Quantcast Help with driveshaft removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Help with driveshaft removal
Old 06-05-2005, 06:30 PM   #1
hungry_yoshi
Hi, I’m new to the jeep community. I’m trying to remove my transfer case, but I got into a snag. I know very little about jeeps. I can’t seem to remove the rear drive shaft. I have a 1997 grand Cherokee with a quadra-trac “on demand” 4wd system along with a Dana 44 rear end. I took off the joint bolts and straps, but the drive shaft won’t fall off. I am also unable to turn the drive shaft. I put the transmission and drive shaft in neutral and raise the rear end off the ground and still unable to turn it. Do I have to lift the front wheels off the ground as well for the drive shaft to turn? How do I go about removing the drive shaft? Also any hints or tips in removing the transfer case would be appreciated.
hungry_yoshi is offline   Reply With Quote
Old 06-05-2005, 06:43 PM   #2
wil badger
well ya if you have the full time case .think about it they are full time meaning both axles are always under power.that means the shafts both have to turn.if your T-case has a nuetral postion that might get the one to spin opposite of the other.if you have undone the bolts and straps you might have to give the drive shaft a smack with a hammer down by the axle yoke
One Built XJ
wil badger is offline   Reply With Quote
Old 06-05-2005, 07:26 PM   #3
greasefingers
1994 ZJ
That’s right smacking it with a rubber mallet or heavy hammer, will do it. It will swing in two directions. It should be obvious from the way you removed the clamps.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Glock Forum
