HELP! Does 3.5 lift need extended bump stops? - JeepForum.com
post #1 of 10 Old 04-04-2014, 08:15 PM Thread Starter
GR8_YT
I ordered a RE 3.5" lift kit for my 96 ZJ, which I plan to install tomorrow
I don't see bumpstops in the kit. Do I need extended bumpstops?
I was considering a 2" BB for a while but eventually decided to get the 3.5" lift. When I was researching the BB I remember some came with extended bumpstops, or that some recomended them. It never crossed my mind if this is necessary for a 3.5" lift until now...
GR8_YT is offline
post #2 of 10 Old 04-04-2014, 09:32 PM
sskilla
If you intend to flex it or wheel it hard I would recommend getting some yes.
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #3 of 10 Old 04-04-2014, 11:14 PM
Myusername1674
Depends on the tire you run in my opinion.
sent from, uh
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #4 of 10 Old 04-04-2014, 11:59 PM Thread Starter
GR8_YT
I'll be running 235/75/15 (~ 29")for a while, just got the not too long ago.
Some wheeling, not too hard. But I'll occasionally be loading her up with heavy stuff, I use the zj to haul landscaping stuff
GR8_YT is offline
post #5 of 10 Old 04-05-2014, 12:42 AM
Myusername1674
Okay you should be fine, as those tires can be stuffed at stock height. If you ever go larger tires look into bumpstopping more. Google hockey puck bumpstops jeep. It's the easy way
(in progress)
post #6 of 10 Old 04-05-2014, 05:52 AM
ejschultz
It doesn't matter so much for tire size as it does for shock compression. You don't want the shock to become the bump stop (unless they're DT8000s with built in bump stops). That'll shorten the life of the shock. Since the lift shocks are longer than the factory shocks, they'll probably be used as a bump stop before the factory bump stops act as they should. Get some hockey pucks for the front and get the RE rear extensions. Summit Racing sells the RE stuff and hockey pucks are cheap on eBay. Do the lift but don't wheel it until you get the bump stop issue fixed.
ejschultz is offline
post #7 of 10 Old 04-06-2014, 07:15 AM Thread Starter
GR8_YT
How many hockey pucks would I need? I'm putting a 3.5' lift, is the assumption that I should extend 3' - 3.5' front and rear correct?
I installed the rear lift yesterday and discovered one bump stop was missing, the other crumbled off when I touched it. So now I have no bump stops in rear
I'll be doing the front today, hopefully I won't find surprises there.
GR8_YT is offline
post #8 of 10 Old 04-06-2014, 10:08 AM
CatSplat
1994 ZJ
It's a combination of both. Bumpstops keep your shocks from topping out as you mentioned, but they also keep an oversized tire from stuffing itself into your sheetmetal at full bump, which can be a bad situation for your tires and a number of your axle parts.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #9 of 10 Old 04-07-2014, 02:55 AM
ejschultz
Measure the amount of travel the shock has and measure the distance between the stock bump stop and inside the coil at the base of the perch. That'll give you an idea as to how much up travel you'll have. You need to get the distance between the bump stop and the perch to be maybe about an inch shorter (because bump stops will compress on initial contact) than the shock.
Keeping this in mind, if you go with a 31, you shouldn't have to worry. Now, I run 31s on 4" of lift with no rubbing. I'm also at 4" of backspacing on 8" wide rims. I'd venture to say different widths and backspacing combinations may produce some issues.
post #10 of 10 Old 04-07-2014, 05:02 AM
Technohead
A lift kit without extending bump stops does not give you any extra clearance at full bump. Or even worse, the shocks bottom out before the bump stops contact.
The proper amount of bump stop depends mostly on the stroke of your shocks and tire size.
-Eric
Technohead is offline
bump stop , lift kit , zj
