Help! Dana 35 or Ford 8.8 on budget? - JeepForum.com
post #1 of 12 Old 04-09-2013, 07:32 AM Thread Starter
94whitewidow
1994 ZJ
I have a 94 zj 4.0l auto with a 249 tcase on 32x10 tires 4.5 inch lift. I have decided the stock gears have to go and I've picked 4.1s to replace them this should get me in the rpm range I want to be in at highway speed. My troubles now are should I just swap out the gears on my old 30 and 35 to 4.1s or keep my 30 with new gears and get a 8.8 that has been built for a zj with 4.1s I don't trail drive much but I do tow trailers with quads or a bike please give me some input on what would be best for me for my wallet and my needs.
94whitewidow is offline
post #2 of 12 Old 04-09-2013, 07:52 AM Thread Starter
94whitewidow
1994 ZJ
ohh and I do plan on ditching the 249 for a 231 and the 32s will be going to more streetable tires in a 31x10.5 size soon and a possible 4.0 stroker motor in a year or 2.
post #3 of 12 Old 04-09-2013, 08:12 AM
DickDickle
Don't you mean 4.10's not "4.1's"??
DickDickle is offline
post #4 of 12 Old 04-09-2013, 08:16 AM Thread Starter
94whitewidow
1994 ZJ
Yes. sorry typo
post #5 of 12 Old 04-09-2013, 08:19 AM
WhiteOut
WhiteOut's Avatar
Just keep the 32s and go with 4.56 gears.
Also, I would change out your rims. 10.5" wide tires on a 10" wide wheel is not a good combo
WhiteOut is offline
post #6 of 12 Old 04-09-2013, 08:44 AM Thread Starter
94whitewidow
1994 ZJ
4.56 is just a bit to low for my needs I'm on the road more then the trails so I have to think about my mpg and the rims are a guess they might b 8 inch I just got this jeep a few weeks ago haven't had much time to check the small details all I know right now its a pig after 3rd gear and I have found a 8.8 built for a zj with 4.10s and factory limted slip with 4 link brace for $1100 just trying to see if spending the extra money will pay off for me in the long run I do plan to wheel more now that I have a lifted rig but mpgs and power to haul are goal #1
post #7 of 12 Old 04-09-2013, 08:45 AM
JohnnyZJ
just the gear swap in what you have will be easiest.
for your intended plan the stock diffs should be fine
07' JKUR rollin on 35s
JohnnyZJ is offline
post #8 of 12 Old 04-09-2013, 08:48 AM
Technohead
What's the difference? Same number.
-Eric
Technohead is offline
post #9 of 12 Old 04-09-2013, 09:01 AM Thread Starter
94whitewidow
1994 ZJ
Cool thanks any company's you would suggest for all the hardware I need?
post #10 of 12 Old 04-09-2013, 01:19 PM
kg6mov
Hears the voices
kg6mov's Avatar
Swap in a d44a from a post 96 V8 if you're worried about strength. Since you're doing regear anyway it's all bolt in.
kg6mov is online now
post #11 of 12 Old 04-09-2013, 01:54 PM
speedbucket
Just swap both front and rear with a v8 96-98 zj and (3:73) call it good. Sell the 4.10s to a highschool kid with a tj. D35 is fine for 31s. I beat the piss out of mine with worn out LSD and it only bent shafts and crushed out wheel bearing cages.......on second thought just get rid of the 35.....
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #12 of 12 Old 04-09-2013, 02:08 PM
riot1987
This may be your cheapest/easiest way to go. You could pick up a 44 cheap. a 44 would give you a larger R&P for towing and Itll be plenty strong for your application. Plus you could work on that rear axle while still keeping your Jeep drivable until you're ready to gear your D30
Build thread^^
riot1987 is offline
