Help with D35 Axle seal replacement - Page 2 - JeepForum.com
post #16 of 18 Old 08-23-2009, 12:59 PM
elmer_fud
Originally Posted by bbehnke View Post
if the wj has no C-clips, how much different is the process? would you need to get the bearing and seal pressed on?
I think so
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #17 of 18 Old 08-23-2009, 04:03 PM
318jeepcherokee
yes.. just did my dads 01 GC..
there is a retainer behind the hub with four nuts on it.. spray the nuts with PB blaster or something that will help brake down rust.... after all four nuts are off get your slide hammer on the hub and starting pulling on the axle.. eventually the axle will slide out of the housing and reveal the seal, bearing and retainer... all data says drill a hole in the retainer and use a hammer and chisel to brake the retainer so you can get the bearing off... i chose a torch and cut the retainer and bearing off( be care full so you don't cut into the axle it self.
Now you can slide the new seal on the axle shaft(before doing this pack the seal with some grease to lubricate it and then slide the new bearing down the shaft ( pack it with grease to) it will only go so far before you need a press.. make sure you press the bearing on with the press pushing on the inner race of the bearing DO not use the new retainer to press the bearing on because it will distort the retainer and the axle wont sit proper in the housing.. trust me i learned this the hard way.. and then press the new retainer on the axle shaft and reinstall into the housing.
tighten all four nuts and your good to go.. also top up diff fluid.. i pulled my cover and cleaned everything up before finishing up.
connor.
-1998 grand cherokee 5.9- custom intake, MTX sledge hammer sub with two JBL audio speakers in the rear doors and JVC deck, Westin safari bar with two 6' lights, Yakima load warrior with reverse lights, Hooker aero chamber muffler.
318jeepcherokee is offline
post #18 of 18 Old 09-22-2009, 01:53 PM
metalli445
Can this same process be used for replacing the bearing and axle seals on a D35 on a TJ? My seal is leaking and needs replaced. I'd like to do it myself but I haven't found a step by step process like this yet to do it. Any help is much appreciated. Thanks
metalli445 is offline
Inner axle seal replacement.... (OllllO) ZJ Grand Cherokee Forum 3 10-19-2009 01:13 PM
04 WJ Front Axle Seal Replacement NewAlbanyWJ ZJ Grand Cherokee Forum 4 04-24-2009 08:58 PM
D30 inner axle seal replacement BradMB2004 ZJ Grand Cherokee Forum 0 12-30-2007 10:12 AM
Front Axle Inner, and Outer Seal Replacement BucYouUp68 ZJ Grand Cherokee Forum 3 12-01-2007 09:08 PM
WJ Axle seal replacement questions pushead ZJ Grand Cherokee Forum 0 10-18-2006 09:00 AM
