help with code P-1494- leak detection pump - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > help with code P-1494- leak detection pump
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-21-2006, 11:44 AM   #1
askoop
got in this morning and threw the code P-1494, Incorrect input state detected for the Leak Detection Pump (LDP) pressure switch.
What does this mean, and how can I fix it?
Thanks
-Adam
His: 2000 WJ, 2.5" BB, mx-6 shocks, Rancho 5000 Steering Stabilizer, 245/75/16 MTRs, 1" addco rear sway bar, 9005 fog upgrade
Hers: 03 KJ, 5-speed, 245/70/16 General HTS
WTB: 1 Timberline wheel or a set of JK steelies
askoop is offline   Reply With Quote Quick reply to this message
Unread 07-21-2006, 12:01 PM   #2
Meerkat
Adam, there is a pump under the hood on the driver's side firewall. It's purpose is to pressurize the evap system to check for leaks. It does this quite often over and over. The code is saying there is a problem with the pump itself. You'll want to locate the pump, then ensure it has power. You may have to replace the pump at some point.
If the pump itself has gone out, that is the only code you should get. It won't affect how your Jeep runs or drives. It is simply a piece of built in test equipment.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline   Reply With Quote Quick reply to this message
Unread 07-24-2006, 11:32 AM   #3
askoop
Thanks Warren-
I found the pump (between air box and headlight) and traced all the vacuum hoses. Found one that was disconnected, connected it back up and after a few trips, the MIL went off.
Thanks for your help!
-Adam
