HELP!! chasing a gremlin - JeepForum.com
post #1 of 11 Old 12-08-2011, 09:53 PM Thread Starter
hickchick805
I can not get my poor jeep to start! it randomly sputtered and died about a month ago. Basically it has spark it has fuel and compression. I have checked fuses, replaced the distributor, a number of sensors ( after changing fuel regulator sensor it ran drove it 5 miles to gas station then died again started up tried to make it home died 4 times on the way home now wont start at all)
I took it to a jeep mechanic and he told me he had know idea what was keeping it from running. I love this jeep to much to just junk it but have had multiple people basically give up. Now i just found out a few months ago the thing had an alarm it went off on me out of the blue got it to turn off and it started up just fine since then. Alot of other weird symptoms have been going on like back up lights not turning on (NSS is fixed now), and the day before it broke down lost high on windshield wipers, also right before it broke down i started it up put it in reverse and it revved up actually moving the jeep while my foot was still on brake.
I am lost as to what it could be now. Does anyone have any ideas? I love this jeep to much to completely give up. (also have tried the unlocking and locking all the key cylinders)
hickchick805 is offline
post #2 of 11 Old 12-08-2011, 10:09 PM
tfink
I have a 93 zj sat for about a year and I had to put fuel lines in it and did that it would start run for awhile then few weeks later it would run, comes to find out I just needed a new computer. But previously I put 500$ into fuel put cause the dude next store shop and him is a rip off, I don't have a probable now after getting the the computer form pick and pull but probable be better to get a new one.
tfink is offline
post #3 of 11 Old 12-08-2011, 10:53 PM
PolkaPower
What?
PolkaPower is offline
post #4 of 11 Old 12-09-2011, 03:40 AM
mojop79
Originally Posted by PolkaPower
What?
Lol, no crap!
mojop79 is offline
post #5 of 11 Old 12-09-2011, 07:33 AM
sebian
I think what he was trying to get across was that he was having the same symptoms, and that after getting screwed by a mechanic, discovered that his PCM was bad. Replacing it did the trick for him.
As for OP, have you tried swapping out the ASD relay with another known good one? When you changed out the sensors, did you also do the crankshaft position senson? If so, did you use a Mopar sensor? These Jeep are very picky about their sensors, so it does matter which brand sensor you used.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #6 of 11 Old 12-09-2011, 09:44 AM
speedbucket
Check the connection of the small black wire on the negative battery terminal.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #7 of 11 Old 12-09-2011, 01:56 PM Thread Starter
hickchick805
crankshaft position sensor was checked not replaced by the mechanic i took it to. The computer checked out according to the mechanic and have checked to see if power is get to it and past it and that checked out fine. I am lost as to why it isnt starting. it cranks but doesnt fire it has backfired a few times when trying to start it checked the cat to see if it was plugged it was fine. i know fuel is getting into the engine since i can smell it everytime it floods it and i know the timing is right since i have replaced distributor and timing chain and am getting spark to the plugs. i just dont get it :
post #8 of 11 Old 12-09-2011, 02:06 PM
jeepmanzj1955
possibilty
i have a 96GC and had some of the problems you had and it turned out to a pesky crank position sensor. one minute it worked the next it wouldn't.
now my son has a cherokee that was doing what yours is doing,and it turned out to be his nuetral safety switch. we cleaned it and so far everything is fine. Do you know if you jeep has a aw4 tranny in it? that is that trannys
achilles heel i've been told.
jeepmanzj1955 is offline
post #9 of 11 Old 12-09-2011, 02:48 PM
azgrandjeeper
I agree with the crankshaft sensore and the PCM. I just got over this problem with my jeep and it turned out to be a loose ground wire. It was sometime getting a ground and then it would not. So it was studdering and then not. But you just gotta remember that Jeep and Chrysler has always had some dumb *** electrical problems. That is the olny thing I hate about my jeep. I have had 3 issues obtaining something electrical.
azgrandjeeper is offline
post #10 of 11 Old 12-09-2011, 04:06 PM
JS97ZJ
Have you checked for mil codes? (cycle key on & off 3x),
Swap the ASD relay
Test the TPS
Problems like this usually start with the everyone's favorite (CPS), but first start with the coil. Check to see if you have good color from the center wire to ground. (bright white, arcing 1/2")
swap the ASD relay with another relay with the same # (horn).
Then test the TPS.
Check your grounds to the engine block and inspect the battery terminals.
Change the CPS.
There is also a problem with the PCMs from 93-95. the capacitors in the computer module are known to go bad after many years of service. They can easily be replaced if you know how to solder (or know some one who does).
http://www.jeepforum.com/forum/f13/f...riteup-501951/
The caps in the PCM, hold in the ASD relay energized.
When you have your foot on the brake, do you loose brake pedal? A bad brake booster will leak vaccum , and cause the engine speed to increase slightly. Try depressing the pedal while in park and check for idle increase.
JS97ZJ is offline
post #11 of 11 Old 12-10-2011, 01:36 AM Thread Starter
hickchick805
well we have done of all these things i have been on this forum for hours talked to multiple mechanics and basically today after one coming out and tinkering with the distributor he thinks the cam shaft has rounded becuz if you jiggle the distributor while trying to start it he catches for a second but not completely. everything external of the engine checks out fine and have replaced alot that wasnt up to snuff so now i have gotten it down to basically something internal is wrong... never rebuilt an engine but looks like im gunna have to learn :
chasing down a steering issue schapkern ZJ Grand Cherokee Forum 15 12-02-2011 10:00 PM
Im tired of chasing this ticking when turning fr33zypop ZJ Grand Cherokee Forum 7 08-08-2011 09:06 AM
We have a gremlin AmbuGrl ZJ Grand Cherokee Forum 17 11-14-2009 02:16 PM
Tired of chasing rainbows. Driveline vibes. crashcraddock ZJ Grand Cherokee Forum 3 05-19-2009 07:29 AM
Need help with electrical gremlin Beamer13 ZJ Grand Cherokee Forum 1 02-18-2009 10:24 AM
