HELP! Car fan stays running! - JeepForum.com
post #1 of 15 Old 07-25-2009, 02:17 PM Thread Starter
DjJester88
Hello, I'm new to this forum, and I own a 02' Jeep Grand Cherokee Laredo. And just last night when I turned off the car, it sounded as if there was a fan on, so I thought nothing of it, went in my house and came back this morning and now the battery is dead, what should I do? It turns on when I use jumper cables, and runs fine after.
DjJester88 is offline
post #2 of 15 Old 07-25-2009, 03:08 PM
j.love
j.love's Avatar
1994 ZJ
If you want help with your car your on the wrong forum. Nice Jeep by the way.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #3 of 15 Old 07-25-2009, 03:18 PM
01Limited45324
It took the same amount of work to not answer his question as it would've to just tell him what needed to know.
It's not unusual for the fan to remain running after the vehicle has been turned off, but it usually isn't for too long. Was your battery low in power to begin with? Anything else might've done this, i.e. did you leave interior lights on or not shut a door all the way?
-Tom
2001 Grand Cherokee Limited
2002 BMW 530i
01Limited45324 is offline
post #4 of 15 Old 07-25-2009, 03:30 PM Thread Starter
DjJester88
Haha, sorry for posting in the wrong threads, but I always make sure my doors are closed properly, and the lights off too. As far as the battery, I'm not too sure on how much power it has left. But I was also reading other threads such as this one http://www.jeepforum.com/forum/f13/fan-stays-after-wj-off-496941/ and they're talking about relay switches, which one in particular would be the culprit?
post #5 of 15 Old 07-25-2009, 05:02 PM
j.love
j.love's Avatar
1994 ZJ
oh please relax, helping the newbie out by reminding him he drives a Jeep not a car.
Oh and your answer seemed to help. might as well as insult him some more and ask if he left it in park with the keys in it.
David.
Joe Biden
j.love is offline
post #6 of 15 Old 07-25-2009, 07:39 PM
01Limited45324
I'm all about easy answers. Sometimes it's the simplest things people overlook. Maybe he was listening to the radio with the key in the on position. With the headlights on and A/C blowing.
-Tom
2002 BMW 530i
post #7 of 15 Old 07-25-2009, 11:14 PM
alexsious
mine did this. its the fan relay located under the passenger headlight. To replace it, you either have to cut a whole in the plastic under the light (easy method) or remove the front bumper and get it from there (harder way)
alexsious is offline
post #8 of 15 Old 07-26-2009, 11:39 AM
terryj
2015 WK
Mine did the same thing also, a first it wouldn't shut off then after it did shut off it wouldn't turn on creating an overheating problem, the problem is the fan relay.
terryj is offline
post #9 of 15 Old 07-26-2009, 02:21 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the fans in grand cherokees are not set up to run after the ignition is turned off. if it keeps running you have a bad relay.
ratmonkey is offline
post #10 of 15 Old 07-26-2009, 02:33 PM Thread Starter
DjJester88
I typed "fan relay" on the autozone website and it gives me two results, "Relay - Radiator Cooling Fan Motor " "Relay - Aux. Engine Cooling Fan " which one is it exactly? And j.love, for YOUR information, its not only just a JEEP, its a S.U.V.
post #11 of 15 Old 07-26-2009, 04:27 PM
g-off70
not sure which one but it is about $50 if that helps
g-off70 is offline
post #12 of 15 Old 07-26-2009, 04:49 PM Thread Starter
DjJester88
their both the same price
post #13 of 15 Old 07-26-2009, 07:45 PM
j.love
j.love's Avatar
1994 ZJ
At least you didn't call it a CAR again. :P
David.
Joe Biden
j.love is offline
post #14 of 15 Old 07-30-2009, 11:17 AM Thread Starter
DjJester88
Touche' so does anyone know which exact relay it is? a picture would be helpful
post #15 of 15 Old 07-30-2009, 03:39 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's behind the pass side head light. good luck!
96 zj instrument panel goes out but stays running thingtwo235 ZJ Grand Cherokee Forum 1 08-27-2009 04:05 AM
Fan stays on after WJ is off. FatAlbert ZJ Grand Cherokee Forum 13 08-01-2009 03:01 PM
Jeep starts,revs up and then stalls (once warmed up, cold it stays running). Coletrickle ZJ Grand Cherokee Forum 11 03-18-2009 08:53 AM
Air condition stays on BBBC3 ZJ Grand Cherokee Forum 1 06-03-2007 12:15 PM
ABS light stays on bumanng ZJ Grand Cherokee Forum 1 01-07-2007 05:51 AM
