Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Grand Cherokee & Commander Forum Group > ZJ & WJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 10-15-2009, 01:01 PM   #1
OFFRDWJ
Help, but not urgent ! Rad and rad support (wj)
So I hit the jeep a while back and my rad support is twisted / bent. moving along,
So I went offroading recently at a thick muddy sandy place (gopherdunes.com) and noticed a small leak got home and spotted the broken rad a week later. So I need some advice. Its not leaking to bad but I do need a new one. Im prob going to get a new one...
I think that both of these cause my rad to burst??
My question is should I wait for kevinsoffroad rad support(which cuts out the original one, good!) and I just keep pouring in rad fluid as it leaks or replace the bent one I have with a stock one? I have no idea how I would replace it does it weld in??? the factory one looks like its part of the whole jeep...
I am wondering if anyone else popped their rad / broke it when offroading in thick mud?
(EDITED)
Thanks in advance
OFFRDWJ is offline   Reply With Quote
Old 10-15-2009, 01:06 PM   #2
GraKee99
WJ Lowrider
GraKee99's Avatar
1976 WJ
First, no need for the bold.
You should replace the radiator if it is leaking. Could email Kevin and see if they have a date when it is going to be released and add the support with the new radiator.
Brian
99 WJ
Low riding 31s
76 CJ5
Build in progress
GraKee99 is offline   Reply With Quote
Old 10-15-2009, 01:08 PM   #3
the88thpianoman
Luck favors the prepared
the88thpianoman's Avatar
2003 WJ
Send a message via AIM to the88thpianoman
Crawled. Personally, I'm opting for waiting for the KOR support, granted a don't have any leaks, just a bent up rad and condenser. The KOR support is supposed to be out more or less now. I talked to Bryant like three or four weeks ago, at which point the ETA was three weeks.
I say waste a few bucks on coolant, don't waste money on welding up another stock support, and spend the money on the upgraded support with recovery as soon as it's available.
2003 WJ in Jeep Green Metallic, 4.0/242/3.55's. 2" BB w/ Rancho RSX shocks, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: http://www.jeepforum.com/forum/f197/the88thpianomans-life-lessons-budget-build-thread-680342/
Green Jeep Club member #136
Jeep nightcrew club member #45
the88thpianoman is offline   Reply With Quote
Old 10-19-2009, 11:35 AM   #4
OFFRDWJ
alright thanks, hope it comes out soon
Old 10-19-2009, 11:50 AM   #5
gbauer
If you can see where it's leaking, you can patch it temporarily with some JB weld.
I did that with an S-10 in college and the patch held up for 80k miles. Easy fix.
gbauer is offline   Reply With Quote
Old 10-19-2009, 05:22 PM   #6
JamesLouis
Send a message via AIM to JamesLouis Send a message via Yahoo to JamesLouis
I just used Alumaseal from Autozone to fix a pretty serious leak in my WJ. I used it back in the day on 2 other vehicles I've owned and it held up for the 2 years I owned both of the vehicles. It costs $3 so if it doesn't work you're no worse off than when you started. Some people swear by Bars Leak. Either way, it's cheaper and faster than any other option and might hold up for you as well as a new rad would. Good luck.
P.S.- Replacing the rad involves removing the bumper, headlights, the hood latch; pretty much everything you see in front of the rad has to come off.
JamesLouis
JamesLouis is offline   Reply With Quote
Old 10-19-2009, 08:09 PM   #7
xJoshxx
Optimus DubJay
xJoshxx's Avatar
Send a message via AIM to xJoshxx
that **** eats your water pumps!
Interested in Amsoil?
xJoshxx is offline   Reply With Quote
Old 10-19-2009, 09:39 PM   #8
patrick983
i just put a brand new radiator from radiatorbarn.com in my WJ. 5th car ive put one in, all others were european cars (including a boxster) and this was by far the most complicated of them all. My brand new radiator is leaking (defective?) and im NOT taking it out again, it took 10hrs the first time. JB weld seems to be holding for now, and some thread sealer on the leaking trans cooler fitting is working well too. id definitely say wait and do it all at once, it would be alot easier w/ the support temporarily out of the way
2000 WJ limited QTII 4.7L 90k
patrick983 is offline   Reply With Quote
Old 10-19-2009, 10:41 PM   #9
dougy147
When I did my heads, the rad was one of the first things I pulled and I did not take off the front fascia, etc. I know there were a few bolts that were not exactly easy to get to, but far from impossible. Is all of that really required?
If you're going to use a stop leak, at least use one that you can drain the coolant (save it), fill systemm with water and sealer, then drain and replace coolant. At least you won't have goo floating around in your cooling system long enough to fill every crevace it can find....
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0
The Present
2000 WJ Laredo 4.7
The Future
dougy147 is offline   Reply With Quote
Old 10-20-2009, 07:09 AM   #10
gbauer
Preferably DON'T use stop-leak!
Patch it from the outside if you can get to it. Stopleak will just clog up other vital ports in the engine.
Old 10-20-2009, 08:37 AM   #11
patrick983
stop leak clogged my heater core and started a leak at the heater core. Luckily back flushing and a coolant change fixed it. DEFINITELY dont use any type of stop leak product. These rad's arent too hard to patch from the outside once u find where the leak is. Both mine leak where the plastic endtanks connect.
Old 10-20-2009, 11:16 AM   #12
JamesLouis
Usually the heater core gets clogged if you don't turn the heat on when you put the stop leak in, which the directions explicitly direct you to do. And I'm very curious as to how a sealant would CAUSE a leak in your heater core Are you sure it wasn't the same leak that everyone with a WJ has has with their heater core that happens regardless of stop leak or not?
Like I said, I've used it in 2 vehicles prior to the Jeep with no detrimental effects. I will say that I drained the coolant after the leak stopped so I didn't have crap floating around my engine looking for a home. Clearly, replacing the rad would be the best of choices if time and money wasn't an issue for anyone but sometimes it is and I thought I'd help out. Use it or don't, I won't be offended.
JamesLouis
Old 10-21-2009, 02:35 PM   #13
OFFRDWJ
i was told the rad support from KOR is a month or so awaay
HID Support? TheTrot WK & XK Technical Forum 17 12-09-2008 09:59 PM
Finally..... Thank you for your support zaq123 ZJ & WJ Technical Forum 6 05-12-2007 09:42 PM
KOR Radiator support S_L_W ZJ & WJ Technical Forum 5 02-02-2007 09:16 AM
Rad Support Slamm36 ZJ & WJ Technical Forum 3 07-25-2006 06:20 PM
Jeepforum support Texas ZJ1 ZJ & WJ Technical Forum 80 11-19-2005 05:45 AM
The time now is 02:41 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
