HELP brakes still grinding after brake job :confused: - JeepForum.com
post #1 of 4 Old 01-15-2008, 07:44 AM Thread Starter
bobwj
o.k. I put new pads on my wifeís limited last night no need for rotors as I did them last time and still looked good. Before the brake pads were replaced I thought that they would be real bad but they were not bad at all. I put the new ones on and took it for a ride. Not change I still had bad grinding on the passenger side. So now I donít know what could be wrong. Maybe the hub is going bad. It only makes that grinding sound when the truck is stopping. It has 135,000 on the clock v8 and a 2000 grand Cherokee.
bobwj is offline
post #2 of 4 Old 01-15-2008, 08:36 AM
nashmd454
nashmd454's Avatar
are there any groves in the rotors...did you grease the backs of the pads...maybe a caliper piston is bad or the slides. Could be one simple thing or a lot....if you can take a pic it may be easier for us to see what you are and tell you a better answer.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #3 of 4 Old 01-15-2008, 09:30 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Have someone walk beside you while you drive slowly. Noises can "seem" like they come from different places while inside the vehicle.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #4 of 4 Old 01-15-2008, 03:35 PM
_Kyle_
_Kyle_'s Avatar
Very well could be the hub, not saying that's what it is though. Typically, the hub will make a grinding type of sound, but any number of things can indicate a bad hub. I orignially thought I had a brake sticking because it was grinding (sounded like a cd stuck in the drive). I jacked it up and had play in the wheel so I replaced both hubs - problem solved. Mine went out with like 140k or so on the clock in the 96. I just helped smrtjustin do his in his XJ a few weeks ago and he only has 57k on the clock...
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
New calipers/brake line/pads, bled brakes, now i have no brake pressure! klwong1 ZJ Grand Cherokee Forum 13 11-16-2013 09:15 PM
ABS? Very bad noises, brakes grinding? Monsterkx117 ZJ Grand Cherokee Forum 3 12-21-2009 12:42 PM
Rear Brakes - rotor grinding into caliper mount crewchiefpro ZJ Grand Cherokee Forum 2 08-03-2009 05:11 PM
Grinding brakes question COYJ ZJ Grand Cherokee Forum 1 03-08-2009 04:58 AM
Front End Grinding - Not Brakes/Bearings Nabis ZJ Grand Cherokee Forum 9 11-01-2007 02:46 PM
