Help! AX-15 Swap ECU Reprogram - JeepForum.com
post #1 of 34 Old 01-17-2013, 06:03 AM Thread Starter
southside
To cut to the chase: I remember reading here once about some dude sending his ECU to a shop in Michigan that was able reflash the firmware to work with a 5-speed instead of an auto. Does anyone know of that shop or the guy who got his OBD2 ZJ to play nice 'without' a tranny?
The long and short of it: Last winter, I yanked out my old worn automatic and swapped in a low mileage AX-15. Since my ZJ is OBD2, I was able to get everything but an ECU. It has been running without a hitch, since.
My only problem is: my Jeep is up for emissions testing this March. The ECU thinks my tranny has taken a long walk off a short pier and is setting off the Check Engine Light. The state funded emissions centers won't even pull the vehicle into the bay if that light stays on once the car is idling.
Any hints, ideas, contact info or encouragement would help a LOT.
I love this thing and now that it's a 5-speed, I can't even see getting rid of it.
southside is offline
post #2 of 34 Old 01-17-2013, 06:13 AM
Rich93ZJ
pull the bulb.
Rich93ZJ is offline
post #3 of 34 Old 01-17-2013, 06:15 AM Thread Starter
southside
Hahaha...that would work if they didn't require it to illuminate with the key in the ignition.
post #4 of 34 Old 01-17-2013, 09:40 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I talked with several companies about it. They could alter the performance so that it would work better with the manual, it has different idle and engine braking characteristics, but couldn't do anything about the check engine light. That's hardware and not a program change. Can't get rid of it on the obdii.
ratmonkey is offline
post #5 of 34 Old 01-17-2013, 03:13 PM Thread Starter
southside
How recently did you speak to those companies?
post #6 of 34 Old 01-17-2013, 04:09 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
couple years back. the guys that designed the PCM's said they can't remove the parts of the main program that reference the TCU hardware.
post #7 of 34 Old 01-18-2013, 04:57 AM
ZeeJay1997
Would it be feasible to install an ECU for a manual and adapt the harnesses and sensors to accompany it? You would be converting it to OBD1... to much to think about this early... lol
ZeeJay1997 is offline
post #8 of 34 Old 01-18-2013, 05:05 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Wire the light to come on with the key on, and off with engine running?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 34 Old 01-18-2013, 02:19 PM
nickpequignot
Could a obd2 xj ecu be able to made work? Maybe even just enough to pass emissions test then switch back to the zj ecu. I'm just thinkin out loud on this. Any input on this?
nickpequignot is offline
post #10 of 34 Old 01-18-2013, 02:30 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
it's been tried, they don't work with zj's. though the v8 works with dodge ecu's.
i can't tell you why they're so different, only that they are. no one has found a work around to my knowledge.
post #11 of 34 Old 01-18-2013, 02:34 PM
nickpequignot
Did you put a dodge ecu in your zj?
post #12 of 34 Old 01-18-2013, 03:21 PM
kg6mov
Hears the voices
kg6mov's Avatar
I agree with max, wire the cel to the abs or similar light so it comes on at ignition and then goes off with the rest of them.
kg6mov is offline
post #13 of 34 Old 02-13-2013, 07:04 PM Thread Starter
southside
I think that might be my only 'legal' way out. I can't imagine why they wouldn't work with one another...
Even if I could pull the whole harness off a junked XJ...it's all the same plugs, right?
On the other hand, my cluster is on its way out anyways. My coolant temp is pegged at zero... maybe I should rig it.
Problem is... they still scan the car for stored codes. If they can't flash the bulb on command, I'm SOL.
Back to the drawing board.
post #14 of 34 Old 02-14-2013, 10:20 AM
jmonty0523
I was talking to a friend who is an electrical engineer, it might be possible to dummy some of the sensors. Govenor pressure would possibly be hardest
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #15 of 34 Old 02-14-2013, 11:03 AM
nickpequignot
I was just thinking that you could possibly wire something up with some resistors and the such to simulate the transmission is there and everything is good with the sensors.
