Help attaching TC skid to frame - Page 2 - JeepForum.com
post #16 of 18 Old 07-17-2009, 01:09 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by thaBrad View Post
I need them tonight, but thanks for the website. Plus they only had up to 3/8" and I need 1/2". Gonna call around for the serts! Thanks Arlo!
why are you using 1/2 13 bolts to attach a skid plate? that's way overkill.
3/8 is fine, 7/16 is more than enough. remember pressure on a skid plate is going in two directions, neither of them will be pulling down on the bolts and shear forces won't be too significant if you don't catch an edge on anything(which you shouldn't if you designed it well).
ratmonkey is offline
post #17 of 18 Old 07-20-2009, 08:55 AM Thread Starter
thaBrad
The existing holes in the frame were 1/2" so I was just using those and not trying to add more. Found nutserts at fastenal but they had to order. So I used Tek screws we have in the shop, we call them machos. Held good, but added more holes just like I didn't want. But at least they're small. Thanks guys, I'll get a pic up sometime.
3" IRO, Bilstein's, 32" KM's on 17" Soft 8's
thaBrad is offline
post #18 of 18 Old 07-20-2009, 11:15 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
you actually want more fasteners, spreads out the forces on the frame better.
Attaching AM/FM to sirius satelite antenna 05 WK compcrasher86 WK Grand Cherokee & XK Commander Forum 6 06-29-2009 05:31 PM
One of four bolts attaching front DS to the pinion flange. JBN311 ZJ Grand Cherokee Forum 12 04-29-2009 06:14 AM
WJ frame-end lca bushings toledotimber ZJ Grand Cherokee Forum 14 09-16-2006 03:12 PM
No power when attaching battery SilverTSi ZJ Grand Cherokee Forum 11 02-17-2006 07:02 AM
WJ frame changes ??? wvresq ZJ Grand Cherokee Forum 2 09-19-2005 04:06 PM
