Help attaching TC skid to frame - JeepForum.com
post #1 of 18 Old 07-16-2009, 12:37 PM Thread Starter
thaBrad
I work for a metal fab company and had the guys make me a TC skid. I designed it to start right after my cross member and on just past the transfer case. I'm using 4 existing holes in the frame that are 1/2" to use 1/2" bolts. And then making one more for each side right at the cross member. My help question is how to attach to the frame? I see you guys talking about nutserts but don't understand how they work. I thought of welding a 1/2" nut to the frame and bolting into that. But then that will push my skid down that much when I designed it to be the same clearance of the cross member. So if I do the nut weld idea it'll catch anything sliding across it instead of being on the same plane as the cross member. Anyways, any advise would be greatly appreciated. Going wheeling Saturday and would love to have this on.
3" IRO, Bilstein's, 32" KM's on 17" Soft 8's
thaBrad is offline
post #2 of 18 Old 07-16-2009, 01:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
nutserts are pretty much rivets. flare and expand into the hole you need threaded.
ratmonkey is offline
post #3 of 18 Old 07-16-2009, 01:09 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
http://www.nutty.com/threatsert.shtml
You do not need the special tool to install threaded inserts. You can use a standard bolt and some washers to install them.
CJ7-Tim is offline
post #4 of 18 Old 07-16-2009, 01:29 PM
Max78
1992 XJ Cherokee
You can always try some cage nuts for McMaster.com
92 Cherokee - All nude and in need of some tlc!
Max78 is offline
post #5 of 18 Old 07-16-2009, 01:43 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Don't weld a nut to the "frame". If you do, as soon as you put weight on the skid plate it'll push up into the frame. You want a large contact patch between the "frame" and the skid plate.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #6 of 18 Old 07-16-2009, 02:27 PM
ZeJokee
Just go and buy some carriage bolts and fish them through the frame. Use your hand to hold the bolt while you use your other hand to tighten the nut with a lock washer behind it as tight as you can. Then use a impact wrench to pull it tight. I did this a few weeks ago to attack a stock t-case skid plate to my ZJ. Worked like a charm and only took me 15 mins.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #7 of 18 Old 07-16-2009, 08:09 PM
jabsther
2010 JK Wrangler
All I used were standard nut and bolt. Held the nut inside the frame with mechanical fingures to hold it until it was tight.
jabsther is offline
post #8 of 18 Old 07-16-2009, 10:20 PM
sandman
most aftermarket skid plates use self tap bolts on the frame side.
http://www.skidplates.com/TCase_MJ_XJ_ZJ.asp
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 18 Old 07-17-2009, 05:04 AM Thread Starter
thaBrad
OK, I thought my frame is boxed. So how would I hold a bolt or nut inside the frame while trying to thread into it? I guess I could magnet it to help it stay? But the self tapping bolts I'll have to probably try. Thought of welding it but I like the idea to be able to remove it with ease. Thanks for the help guys.
thaBrad is offline
post #10 of 18 Old 07-17-2009, 07:32 AM
ArloGuthroJeep
Mr. Hyde!
Get nutserts...
post #11 of 18 Old 07-17-2009, 08:13 AM Thread Starter
thaBrad
Originally Posted by ArloGuthroJeep View Post
Get nutserts...
I think now I'm just going to tap the hole to thread my 1/2" bolts. Think its good enough? Can you get nutserts at an auto store or a Harbor Freight or something like that?
thaBrad is offline
post #12 of 18 Old 07-17-2009, 08:18 AM
ArloGuthroJeep
Mr. Hyde!
Taping the "frame" on a WJ won't suffice...it is way too thin. There is nothing to tap really. Nutserts are probably available at an autoparts store, not sure though.
post #13 of 18 Old 07-17-2009, 09:14 AM
CJ7-Tim
CJ7-Tim's Avatar
CJ7-Tim is offline
post #14 of 18 Old 07-17-2009, 11:59 AM Thread Starter
thaBrad
Originally Posted by CJ7-Tim View Post
I need them tonight, but thanks for the website. Plus they only had up to 3/8" and I need 1/2". Gonna call around for the serts! Thanks Arlo!
thaBrad is offline
post #15 of 18 Old 07-17-2009, 12:23 PM
Unka-Boo
Most any hardware store should have them. They are the way to go, you won't be able to thread your "frame" as it's sheet metal. ( well, properly anyway )
Unka-Boo is offline
Attaching AM/FM to sirius satelite antenna 05 WK compcrasher86 WK Grand Cherokee & XK Commander Forum 6 06-29-2009 05:31 PM
One of four bolts attaching front DS to the pinion flange. JBN311 ZJ Grand Cherokee Forum 12 04-29-2009 06:14 AM
WJ frame-end lca bushings toledotimber ZJ Grand Cherokee Forum 14 09-16-2006 03:12 PM
No power when attaching battery SilverTSi ZJ Grand Cherokee Forum 11 02-17-2006 07:02 AM
WJ frame changes ??? wvresq ZJ Grand Cherokee Forum 2 09-19-2005 04:06 PM
