Quantcast HELP...All of a sudden a loud clicking/ticking noise after filling up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > HELP...All of a sudden a loud clicking/ticking noise after filling up
Old 05-04-2009, 02:05 PM   #1
JeepMeNow
Thanks!
JeepMeNow is offline   Reply With Quote
Old 05-04-2009, 02:12 PM   #2
Bama_WJ
Bama_WJ's Avatar
Put a tank of higher octane through and see what that does. Its possible you got some bad gasoline.
Daniel
1 Ton WJ Build In Progress
The Daily: 2011 Chevy Cruze Eco - Bone stock and 37 MPG
Newest Addition: 2006 WK Overland - OME HD Lift, 265/70/17 BFG AT's, 1.25" SpiderTrax wheel spacers and more to come...
YouTube. - My Video Channel
facebook. - Wheeling pictures and videos.
The Jeep Wave. Bringing it back.
For Sale Now:
- Clayton 6" Springs
- Bilstein 5100 Series Shocks (6" lift)
For Sale Later (once I get my swap done):
- Brand New WJ JKS Track Bar
- Stock WJ Suspension Components
- KOR 2.5" BB Lift
- Many WJ Drivetrain Components (PM for details)
Bama_WJ is offline   Reply With Quote
Old 05-04-2009, 07:22 PM   #3
melloyello
If it is due to that fill up then maybe a screwed up injector to me. Could be old gas, gas w/ too low an octane rating, gas w/ a lil water, etc. I hope that's what it is. I don't know if it's really as loud as the video makes it sound but it sounds loud enough to worry about.
To me it really sounds worse than something that would have come from a fill up. It sounds more like a trashed lifter.
melloyello is offline   Reply With Quote
Old 05-04-2009, 09:55 PM   #4
Some_Anchovies
dude, I'm 110% sure its the lifter.
Had the same problem on my bro's escort. a piece of sludge might have gotten in there and clogged something preventing oil from getting to valve parts and lifters, causing the lifter to stick and clack. If the lifter is totally shot, you'll have to replace the lifter, or both that and the Cam. FOR GOODNESS SAKE DON'T DRIVE IT AROUND LIKE THAT. You'll wear a flat spot in the Camshaft, which means replacing that lifter will do jack for the noise.
If its just the sludge, you can easily fix the problem like I did on the 'scort. Get new oil, filter, gunk 5 min engine cleaner, and a quart of Marvel Mystery oil from Autozone. Don't drive the Jeep until its fixed, we don't want to pull the head off.
Run the gunk stuff through there first for about 5-7 min. If the engine starts to run a little rough, shut it off, as the oil is probably breaking down about now from how strong the stuff is. Drain the oil and take off the filter. Once its drained, leave the oil plug off and pour a small amount of oil into the valve cover to flush out any remaining stuff from the pan.
Let the engine cool off. Then, put new filter on, plug back on the pan, and then pour the Marvel Mystery oil in first. This stuff won't breakdown the oil, and it cleans the engine up nice and good, but at a much slower rate. then pour the oil in. run the engine, but AT IDLE ONLY until operating temp is reached. run the engine as long as you'd like, but once oil pressure is getting below 35, I'd shut it off and let the engine cool.
The next day, start it up, after about 10 seconds, the noise should be quieter now. If not, it might not be the sludge problem. Keep doing the running it till its warmed until the noise is gone.
This is one of the better ways of doing it before you start taking off the head to replace a lifter that might not need replacing, just a sludge clot cleared. Much cheaper.
Check and see if the noise is coming from the valve cover first though. The noise should get louder when you take off the oil cap on the valve cover. If its not coming from the valve train, then we'll have to look elsewhere for the problem, but if it is, try this first.
Some_Anchovies is offline   Reply With Quote
Old 05-04-2009, 10:16 PM   #5
tsconver
Hooligan
tsconver's Avatar
2003 WJ
unfortunately if it is a lifter that has died, you have to pull the head to get the lifters out on the newer I6s
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/hh219/benumb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/hh219/benumb55839/jeep/image0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Old 05-04-2009, 10:19 PM   #6
Some_Anchovies
Pulling off the head sucks. Which is why I'm hoping that its just a sludge clog.
Old 05-04-2009, 10:29 PM   #7
JeepMeNow
Thank you all for your replies.
Old 05-04-2009, 10:39 PM   #8
Some_Anchovies
didn't try seafoam. You could try that instead of the gunk stuff.
I don't know. Probably a lot. They'd charge you to take off the head, which requires taking off the intake manifold, exhaust manifold, valve cover, rockers, and any other parts that get in the way. Labor costs would be extreme.
Try that thing I did on my brothers escort. Its a trick my grandpa said has saved many cars from going through the trouble of getting a head removed, lifter replaced, valve guides redone, camshaft put in. He was a mechanic for 30 years, and I go to him for all my tricks and tips. works everytime.
Old 05-04-2009, 10:47 PM   #9
JeepMeNow
It sounds like almost the same product. I love my Jeep!
Old 05-04-2009, 10:52 PM   #10
Some_Anchovies
Your talking about seafoaming into the intake and burning it with the gas. I'm talking about running it into the oil to clear out clots.
Actually, do both. Run seafoam through the intake and burn it out the exhaust to clean the valves, and then another can into the crankcase to clean the oil clogs.
the gunk engine cleaner can't be burned with gas, its designed to clean the oil holes and ducts of sludge and buildup. not the same.
Old 05-04-2009, 11:03 PM   #11
JeepMeNow
interesting!! I will check into your stuff.
Old 05-04-2009, 11:10 PM   #12
Some_Anchovies
yep, that's what you do. Seafoam is much more versatile than that gunk stuff. Seafoam also has instructions on their can. I've used it before, works nice.
Try that Marvel Mystery Oil. Its worked for me in many situations. You can put it in the gas as an upper cylinder lubricant and fuel pump lubricant, or in the crankcase to keep the engine sludge free. I did both on my brothers escort because the engine only takes 4 quarts of oil, so I had some to put into the gas tank (doesn't take much in the tank).
Glock Forum
