Help on the abbreviations??? WK etc.... - JeepForum.com
post #1 of 4 Old 08-19-2004, 07:09 PM Thread Starter
seosg
Hey guys, new to the boards and trying to figure out all these model abbreviations that are used... if someone has a second, could you give a quick rundown, im sure there may be others stumped as i am. Where are they derived from??
Much thanks guys
seosg is offline
post #2 of 4 Old 08-19-2004, 07:53 PM
Jbartman00
On the main page before you actually log into a forum, http://www.jeepforum.com/forum/, you will see that if you read the description for each type of jeep, you will see the letters that correspond to the make. For instance you will see that Grand Cherokees are ZJ's 93-98 and WJs are 99-present. The only one not on there is the WK, which is the upcoming 2005 Grand Cherokee.
Jbartman00 is offline
post #3 of 4 Old 08-20-2004, 02:24 AM
Buddha_Kip
Buddha_Kip's Avatar
They are just factory designation "numbers" to differentiate between model changes. Most every manufacturer has them.
Porsche 911 - pre 1990 = 911 (turbo was the 930 and there was a 912 in the late 60's - 70's), 1990-1994 = 964 (turbo was the 965), 1995-early 1998 = 993, 1998-current = 996...Boxster is 986
Corvette - C3 - 1978-1982; C4 - 1984-1996; C5 - 1997-2004; C6 - 2005+
Mercedes - W124 - mid 80's - 1995 E-Class (except for the 190E which was a W201); W210 - 1996-2001 E-Class; W140 - 1992-1999 S-Class; W202 - 1994-2000 C-Class, W203 - 2001+ C-Class, W129 - 1992-2001 SL-Class
BMW - E30 - 1984-1991 3-Series, E36 - 1992-1998 3-Series, E24 - original 6-Series
mid 80's Plymouth Reliant/Dodge Aries - K-Car
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #4 of 4 Old 08-20-2004, 09:12 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Much thanks guys
Here is more info than you want. http://4wheeldrive.about.com/cs/jeep/l/bljeepcodes.htm
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
Abbreviations Airborne Lee ZJ Grand Cherokee Forum 3 10-11-2005 01:22 PM
