Help, 99 WJ Binding and popping when turning sharply - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Help, 99 WJ Binding and popping when turning sharply
20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!Father's Day & Moving Day Sale!
Unread 08-28-2009, 05:29 PM   #1
bigredjeep95
I just bought a 99 WJ Limited 4x4 a few weeks ago it has 117,000. I replaced a front caliper that was sticking, and released the E brakes manually, had to pound the rotors off.
Anyways, it binds a alot and pops when making sharp turns, would friction modifier be the answer to this due to the limited slip?
Second Problem - The Jeep groans load at around 20mph and gets louder with speed. I've had it on jacks with all the calipers and rotors off and it still does this. Would this possibly be pinion bearings, outer axle bearings, or something else?
I just want to see what other people with problems like this did to remedy it.
Also For Sale - Matching pair of Dana 44 axles off a 1986 grand wagoneer, stock gears, dont know if its limited slip or not. $800 PM me
95 YJ Wrangler - 35" Swamper SSR's, 4.5" Rubicon Express Lift Spring with Spring Over, 4.10 Gears, Ford Dana 44, Ford 9", M8000 Winch
1995 YJ Wrangler- 2.5, 2" Lift 31" Tires
1975 Cherokee S Widetrack, 6" Lift, 35" Baja Claws, AMC 360
2012 Chevy 2500HD 4x4 6.0
2002 WJ Grand Cherokee Limited, AFE Intake,DD
1990 YJ Wrangler - Torn Apart
bigredjeep95 is offline   Reply With Quote
Unread 08-28-2009, 05:38 PM   #2
UltimatE
Resident Audio Guru
UltimatE's Avatar
Front axle u-joints. Most likely the cause of both issues.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Unread 08-28-2009, 06:57 PM   #3
wjcando
WJ's don't have u-joint front axle shafts (unfortunately), and if he broke his cv axle joint he'd be getting so much noise he probably wouldn't go more than a few feet.
And related to that, LOL, about those waggy axles... and idea what the WMS/WMS measurement is?
Frank "it-takes-a-village-to-wheel-a-WJ"
McLean, VA
wjcando is offline   Reply With Quote
Unread 08-28-2009, 07:22 PM   #4
bigredjeep95
WMS is about 61" front and 59" rear
Unread 08-28-2009, 07:26 PM   #5
elmer_fud
check the CV shafts in the front axle
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline   Reply With Quote
Unread 08-28-2009, 07:31 PM   #6
UltimatE
Resident Audio Guru
UltimatE's Avatar
Silly me, didn't read the whole post. Doh.
-Matt
White '94 YJ Sport
