Help!!! - JeepForum.com
post #1 of 9 Old 05-06-2008, 08:20 PM Thread Starter
giantdave
Help!!!
so ive been having problems with my 97 grand cherokee, and i need to drive it 500 miles loaded with stuff back home.
i tried to start it the other day, and it almost didnt start, but i gave it some gas and it was fine. then when i got to where i was going, i shut it off and all the lights died. sounds normal, but the lights arent all suppose to die, like the headlights stay on for a while and stuff. it acted like the battery was dead.
then 10 minutes later the lights came back on and it started fine. then it did it again one more time, and i drove it back to campus and it was fine except all the lights and dashboards were flickering.
now, its running fine, the battery is fine and the alternator is fine. i had those checked at autozone. the only thing now is that the computer thing...the screenthat says a door is opened or when i need an oil change.. it keeps flashing. whole thing on and off, plus th etime keeps getting messed up. and i dunno why
pls help!
rollin in the 97 gc laredo
giantdave is offline
post #2 of 9 Old 05-06-2008, 09:22 PM
Elkaholic
NMElkaholic
Elkaholic's Avatar
Electrical short?? Computer freaking out??
98 5.9, Platinum 4.5 RE SF all adjustable arms, RE Monotube Shocks, Carolina front drive shaft, Pro Comp Extream Alloys Stryker's, 285/75/16 BFG's KM2's,Stage 1 rock sliders,Confer roof rack,Warn XD9000i winch, 3" Kolak exhaust system, Addco front swaybar and lot's more goodies.. 79 CJ5 AMC 304 33x12.5 Pro Comp X-tream mud tires on 15x12 MT classics. 3" lift.
Elkaholic is offline
post #3 of 9 Old 05-06-2008, 09:27 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
have you checked your oil?
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #4 of 9 Old 05-06-2008, 09:30 PM
CrazyWalnut13
Sounds like it's the flux capacitor to me.
(200th post)
Zak
Formerly Default Jeeper #13
2000 WJ Limited 4.7 with stuff. Look left for the deets.
CrazyWalnut13 is offline
post #5 of 9 Old 05-07-2008, 12:18 AM Thread Starter
giantdave
well it does say that i need an oil change. does it flash when it gets to zero? i havent had it long and i dont have a manual.
post #6 of 9 Old 05-07-2008, 01:14 AM
Colorado 5.9
Colorado 5.9's Avatar
Bad ground somewhere or like said above a short somewhere. Sometimes battey cables can get corroded way up inside. It could also be the BCM.
ZJ 98 5.9 LTD. Lots of mods. 7" T&T's Long Arm Lift ,BFG KM2"s,35X12.50x16's,4:56's, Vanco brake upgrade, M1intake,Holley52mmTB,MikeLeach Headers,, Arb'ed HP D30,Aussie Locked rear,Procomp MX6 Shocks,Arb front,RearTR bumpers,ECT.ECT.
Colorado 5.9 is offline
post #7 of 9 Old 05-07-2008, 07:38 AM
TheCompound
1994 ZJ
Mine acted just like that, come to find out the (-) terminal on the battery was loose. Hope that helps
But it does sound like a loose connection somewhere.
-TheCompound
TheCompound is offline
post #8 of 9 Old 05-08-2008, 12:44 AM
the88thpianoman
2003 WJ
that actually really does sound like a battery connection problem... clean your battery terminals, I would bet that solves the problem
the88thpianoman is offline
post #9 of 9 Old 05-08-2008, 01:21 PM
zjhitman
Mine did that right before my battery died. So you either have a loose or dirty connection at the battery terminals or your battery is about to die, regardless of what Autozone told you. Sometimes they have an intermittant dead cell in them.
zjhitman
zjhitman is offline
