help,5.5inch lift on my grand,bad vibrations. - JeepForum.com
post #1 of 7 Old 01-02-2004, 09:17 PM Thread Starter
wegotused
i was hoping someone else had this problem and can help me..i have a 96 grand,4.0,242 t case.4.5 inch rubicon express with 1 inch spacer..34 inch trxus swampers..had vibrations when i first installed lift so i put a slip yoke elim. kit on it..still have vibrations,so bad i rarely drive it..i have put many lifts on and consider myself very mechanically inclined but i cant figure this out.i have adjustable rear arms and pointed my rear pinion up at the transfer case rear yoke as i was told to do when you have a slip yoke elim. kit with a double cardon driveshaft..i took out the front shaft,still have a vibration..any ideas?????i have an awesome looking jeep i cant use..please help..
wegotused is offline
post #2 of 7 Old 01-02-2004, 09:55 PM
DrewT
Did you get a front end alignment after you put the lift on? Also, make shure your tires are balanced....
Good luck
-Drew
DrewT is offline
post #3 of 7 Old 01-03-2004, 06:18 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Where did you get the SYE from? and why? You don't need it for that lift. Did you install the transfercase lowering spacers?
Lots of guys get talked into the SYE. Maybe I've just been really lucky. Yet, I've had no problems at all.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 7 Old 01-03-2004, 11:27 AM Thread Starter
wegotused
Hunter
Hey Hunter,wow you have 6.5 inches and no vibrations,man what did i do wrong..i did install the tcase lowering kit..RE suggested the sye,but it made no difference..im really stumped..thanks for your help..Matt
post #5 of 7 Old 01-03-2004, 12:56 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Are the yokes properly aligned? If you dissembled the driveline at the slip yoke and didn't mark the halves, then you might have reassembled it with the yokes out of "time".This can cause a vibration.
jeepdaddy2000 is offline
post #6 of 7 Old 01-03-2004, 09:30 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Check the yokes, You might want to check and see if you have bent one of the rear axles. Did you have the vibes before the lift or just after? Did you have them before or after a wheeling trip? I knocked a wheel weight off once and the thing vibrated like a mutha until I got it fixed.
Please keep me updated on this. I want to be able to help others with the same problem later on.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 7 Old 01-04-2004, 11:46 AM
mudd
hmm?
hate to sound redundant but check the balancing again. depending on how much you know and trust the people who balance your tires 34" swampers are not easily balanced. i have very reputable people balance my tires and have had them do it for a number of years. yet still once, about six months ago they werent very accurate and i about bounced off the road on the way home at only 35 mph. and i only have 32" mudders. double check by putting on the stock tires and taking it for a spin, youll look silly but it could save you some headache.
mudd is offline
3.5inch IRO lift springs to big? igotsajeep ZJ Grand Cherokee Forum 19 01-26-2010 09:11 PM
Which type of muffler for a 2.5inch cat back? JkTheItalianoWJ ZJ Grand Cherokee Forum 8 08-23-2009 02:33 PM
question on RE 3.5inch lift kylewolf ZJ Grand Cherokee Forum 3 06-26-2007 08:26 AM
zj 3inch to 5inch 1cleanGSR ZJ Grand Cherokee Forum 2 04-09-2007 12:26 PM
5.5inch lift question zj333 ZJ Grand Cherokee Forum 8 07-27-2005 01:37 AM
