Help with 4.0 valve cover leak - JeepForum.com
post #1 of 9 Old 11-11-2005, 08:49 PM Thread Starter
Kcolg
Help....20:30 hours and stuck working on the Jeep still.
My valve cover gasket is leaking, mainly in the to rear portion of the vlave cover. I have taken the bolts out, and even un bolted the throttle body because the cables running over the valve cover would not let me lift it off otherwise. Well no my problem is I can not get the cover to lift all the way off becuase of a vent hose of some sort on the top and back portion of the valve cover. As I try to lift the cover up, this elbow vent hose thing hits the top of the engine compartment and wont give me enough space to lift the cover off. I was able to pull the hose off but do not know how to get the elbow section off of the top of valve cover. I tried turning it, thinking it was threaded and nothing, also tried pulling up on it, but am afraid I am goind to break it off. Any help is greatly appreciated.
Thanks.
1994 ZJ - 4.0 - 242 - 4.5" RE lift - 32" Maxxis Bighorns - 4.11 gears - Super 35 axle - Ected lockers front and rear - On Board Air - JKS Quicker Disco's - ARB front - engine/TC/Gas tank skids - home made sliders - a little of Kevins stuff
Kcolg is offline
post #2 of 9 Old 11-11-2005, 09:52 PM
zjay
Sounds like the pcv valve (actually an orfice) is in the way. I usually remove them with a prybar, and yes it'll break. I usually have another to replace it with. It pulls straight up to remove, but is very tight. You MIGHT be able to free it by rocking it back and forth with 2 screwdrivers as you raise it up. If you can think of some save way to warm the rubber grommet it is in, that may help it it's cold.
96 GC Limited V8 245,000 miles Scrapped
04 GC Limited 4.0 264,000 miles
96 GC 4.0 175,000
zjay is offline
post #3 of 9 Old 11-11-2005, 10:17 PM
-Joe-
-Joe-'s Avatar
You dont have to remove the entire throttle body. The cables pop off and you can just set them aside.
And you can remove the valve cover without removing the elbow section you are talking about. If you twist it the right way you can tilt the cover to the drivers side and slide it right out.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 9 Old 11-11-2005, 10:29 PM Thread Starter
Kcolg
Tried the tilt method and it still was not able to clear. Tried prying the elbow off and "Snap" it broke. Now I have the cover off
Had the hine sight to call Orielly Auto Parts for a new elbow just before I broke it and they have them but it will take a week to get them. Will have to check with the Stealership tomorrow, hopefully they have them in stock. I am just worried about how I am going to get the cover back on once I put the new elbow on. Also broke the plastic hoses that attach to the elbows when trying to "gently" pull them off. Life lessons I guess.
Kcolg is offline
post #5 of 9 Old 11-12-2005, 04:49 PM
ChicagoGuy
Team XBOX
ChicagoGuy's Avatar
I broke the same pieces, pretty much doing the same thing. And while I don't recommend it as a good practice, I just superglued the broken pieces back together until the replacements arrived about 2 weeks later.
I mean, they ARE plastic...and hey, it worked for me.
- Bill (formerly VetteDriver)
ChicagoGuy is offline
post #6 of 9 Old 11-12-2005, 11:11 PM
zjay
Put on the valve cover FIRST, THEN work the elbow into the rubber grommet. It takes a little force and wiggling, but it will go in, a lot easier than it came out. If you look at it when it's out, you'll see the end that goes in is tapered to let it in, but not let it out.
And the hose to it, let me guess, broke at the rubber end to the elbow, right? They usually break there. Get a new one if you can or rig up a hose. It is a vavuum hose and you don't need a leak there.
96 GC 4.0 175,000
zjay is offline
post #7 of 9 Old 11-13-2005, 10:09 AM
Jeep-Tech1
Your local jeep dealer should have those fittings and groments. I've always wonderd why chrysler does not offer a gasket for that valve cover. We replace the whole valve cover when they leak, cause we don't offer a gasket for YM's 93-95. If they want come right off, I break them just like you did to get hem off. No use to try to wrestle with something so cheap.... Good luck...
Jeep-Tech1 is offline
post #8 of 9 Old 11-13-2005, 08:08 PM
jeepjeepster
my dealership had them in stock, got them for our grand cherokee. same thing in the cherokees though. they were like $20 for the front and rear groments and elbows.
jeepjeepster is offline
post #9 of 9 Old 06-19-2011, 04:00 AM
TumorNamedMarla
91 XJ. My first build.
03 TJ Freedom Edition.
TumorNamedMarla is offline
Valve Cover Gasket Possible Leak Wj 4.0 xJoshxx ZJ Grand Cherokee Forum 24 07-14-2009 12:07 AM
2000 wj valve cover leak mselby ZJ Grand Cherokee Forum 4 12-16-2008 01:12 AM
V8 Valve Cover Leak $70 Gasket??? Jon08JK ZJ Grand Cherokee Forum 5 11-07-2007 10:04 PM
Valve Cover Leak oct7brian ZJ Grand Cherokee Forum 22 09-10-2005 07:39 PM
Leak at Valve Cover dpierson ZJ Grand Cherokee Forum 1 09-03-2005 12:09 PM
