Help, 231 for 249 transfer case - JeepForum.com
post #1 of 7 Old 07-02-2007, 06:22 PM Thread Starter
fruitlandgreer
I am fairly new to Jeeps and I got some great replys to the question of what is wrong with my transfercase, but I have one more. Can I replace my 249 with a 231? I have one handy and free so that is why I ask. Please help.
fruitlandgreer is offline
post #2 of 7 Old 07-02-2007, 06:26 PM
jfowlzj95
Yup, and theres a ton of write ups on it too.
95 zj with some big n heavy crap!
jfowlzj95 is offline
post #3 of 7 Old 07-02-2007, 06:27 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the answer is a conditional yes. some zj's had front driveshafts with a cv joint at the tc, you would need a new front shaft(or just a new end put on it) and very likely lengthening of the rear shaft as well.
but the swap it's self is failry straight forward following the instructions for a 242 swap. you'll likely need to swap the input from the 249 to the 231 unless you get really lucky and both are the same length.
ratmonkey is offline
post #4 of 7 Old 07-02-2007, 07:47 PM
j.love
j.love's Avatar
1994 ZJ
the 231 tc case is shorter so you will need to lengthen your drive shaft! 242' are the same size.. but you need to get the same kind of tail shaft as the one you have!
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #5 of 7 Old 07-02-2007, 09:37 PM Thread Starter
fruitlandgreer
Thanks a ton, to all of the answers. Jeep owners are coooooool!!!!
post #6 of 7 Old 07-02-2007, 09:49 PM
jfowlzj95
I had to shorten my driveshaft by about an inch.
When you swap input shafts, make sure the gear cut is the same. Here this is copied over from Jordan on MC, should give you a better idea on input shaft lengths.
Originally Posted by DJJordache
this should help ya... the only one I don't know about are the ones that came with the AX15.....
ZJ 93-93.3 4.0L aw4 = short
ZJ 93-95 4.0L = medium with internal collar
ZJ 96-98 4.0L = medium without internal collar
ZJ 93-95 v8 = long
ZJ 96-98 v8 (both) = medium without internal collar
short = .750" exposed
medium = .840" exposed
long = 1.55" exposed
post #7 of 7 Old 07-02-2007, 09:59 PM
j.love
j.love's Avatar
1994 ZJ
lengthen/shorten.. you will still need to address it cause the two units are not the same physical size. ( I just knew one of them was longer than the other)
David.
Joe Biden
j.love is offline
ZJ transfer case abregar ZJ Grand Cherokee Forum 8 09-08-2007 08:44 AM
Transfer Case Death-Mobile ZJ Grand Cherokee Forum 2 05-05-2007 11:12 PM
Transfer Case HELP!!! TheCompound ZJ Grand Cherokee Forum 3 04-30-2006 08:59 PM
transfer case bill9000 ZJ Grand Cherokee Forum 23 10-04-2005 09:53 PM
Transfer Case? cherokeevince12 ZJ Grand Cherokee Forum 1 09-22-2005 05:55 PM
