hello, general questions... - JeepForum.com
post #1 of 13 Old 03-22-2008, 03:59 PM Thread Starter
robertg
1994 ZJ
hi everyone, long time reader and lurker, finally posting for the first time.
my fiancee has a 94 ZJ, and i get to be its caretaker.
ruby, as leigh anne calls her, has 210k miles on her now, and still gets 22mpg highway. gets better mileage than my 2000 rwd astro van that has 136k miles.
there's some issues that i need to address, and i'm not sure where to look for the information at. i've already changed a cv axle boot on the passenger side, and did both door hinge pins on the driver side front door.
for some reason, the driver side rear door and the liftgate refuse to open.
any major problems with either of these repairs?
thanks!
robertg is offline
post #2 of 13 Old 03-22-2008, 04:35 PM
Intense-Dakota
can you open from the inside of the door, or not at all? If not at all, its gonna be fun. If it does, then it may just be the linkage, which will just require pulling the inside panel off the door, and peaking around to find the culprit.
Intense-Dakota is offline
post #3 of 13 Old 03-22-2008, 04:45 PM Thread Starter
robertg
1994 ZJ
not at all.
same goes for the rear liftgate, i have tried the trick of pushing in on the gate while working the latch. no good on that part. i can't get the liftgate trim pulled far enough back to get my hand in there either. couple screws wedged in underneath against the carpet.
thanks for the quick reply!
robertg is offline
post #4 of 13 Old 03-22-2008, 04:52 PM
Intense-Dakota
ouch, well for the door at least, a slimjim might be your only bet, but for the rear hatch, I am lost on a second option.
post #5 of 13 Old 03-22-2008, 04:59 PM
impuresoul2k3
Yeah, gonna have to find a way to get that back panel off, not sure how easy it will be, I'll take a look at mine tomorrow and see if there is anyway to get it off with it shut. The rear passenger door probably has a broken latch, which isn't any fun to get out either, when my driver side door latch broke, I got the panel off and spent a few hours with a dremel cutting the latch apart enough that it would come out.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #6 of 13 Old 03-22-2008, 05:02 PM
a70eliminator
The stationary catch for the liftgate is bolted down through the floor of the hatch area and you can get at the nuts from between the bumper facia just under the latch, if the bolts are all rusty you mignt not be able to get them loose cause an open ended wrench is just about all you fit up under there. As far as the door goes a slim jim is the ticket if it's a linkage problem, you are aware the doors have a child proof mechanism located on the door in the jamb area, it's a lever that disables the inside handle. Oh also about that rear hatch you'll have to push down on the facia with your fingers to reveal the bolts.
a70eliminator is offline
post #7 of 13 Old 03-22-2008, 05:03 PM
_Kyle_
_Kyle_'s Avatar
The back plate depends how much damage you want to do. You can cut a hole to do your work, or remove some of the screws to try and get it off...but you'll probably break it either way.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #8 of 13 Old 03-22-2008, 09:01 PM Thread Starter
robertg
1994 ZJ
i was wondering how the license plate mounting plate is attached.... the plate itself looks like it is made of some kind of plastic, or fiberglass.
could i get in to the latch from there if any other opening attempts fail?
robertg is offline
post #9 of 13 Old 03-22-2008, 10:13 PM
_Kyle_
_Kyle_'s Avatar
I completely forgot about that. I remember reading about a guy going in that way. I think, but don't quote me, it pops off...but I'm 99% sure the guy ended up breaking it and had to replace that to. But its do able.
Here is the info from my 96 FSM on how to do it:
-Kyle
1996 Grand Cherokee
_Kyle_ is offline
post #10 of 13 Old 03-23-2008, 07:11 PM Thread Starter
robertg
1994 ZJ
hey kyle, thanks a lot! i could probably repair that lamp housing if it breaks on me while trying to access the liftgate in that manner.
that picture really helps me a ton. thanks again!
robertg is offline
post #11 of 13 Old 03-23-2008, 07:50 PM
_Kyle_
_Kyle_'s Avatar
Anytime. I completely forgot about that way to access it.
-Kyle
1996 Grand Cherokee
_Kyle_ is offline
post #12 of 13 Old 03-24-2008, 02:06 PM
dgejeep
What color is your interior?
here is a grey rear panel and top for sale....
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
dgejeep is offline
post #13 of 13 Old 03-24-2008, 08:56 PM Thread Starter
robertg
1994 ZJ
not a bad idea... thanks! is a 1998 trim piece going to be the same as a 1994? i don't care about color, i can always scuff and paint to match.
i'm about to use a window switch panel from a trailblazer to replace the broken one in my astro van. the correct part from gm is part of an entire assembly, and costs about.... $57 my cost through my work at a chevy dealer.
i'll be able to use this experience in making something work on leigh anne's jeep.
robertg is offline
General Questions bbhockey19 ZJ Grand Cherokee Forum 3 01-02-2008 08:15 AM
ZJ - WJ General questions K9-Handler ZJ Grand Cherokee Forum 6 10-18-2007 10:57 AM
5.2L v8 General Questions Deblanc ZJ Grand Cherokee Forum 23 08-08-2007 11:57 PM
Sorry another general set of questions cfkingfish ZJ Grand Cherokee Forum 4 05-02-2004 08:28 PM
General GC questions sknot1454 ZJ Grand Cherokee Forum 6 02-17-2003 11:24 PM
