hellllppp blower motor problem - JeepForum.com
post #1 of 2 Old 01-23-2008, 07:15 PM Thread Starter
Mrd4322
ok this is a complicated situation....i just bought a 2002 grand cherokee limited w/ the automatic heat and stuff....anways my blower motor stopped working and i went to check it out and everything works except the blower,i took a power probe and tested it for power and ground,it has power getting to it but theres something with the ground,i took a piece of wire and put it to a metal bracket under the glove box and put the other end into the connector that connects to the blower...well the motor worked once i did that on all speeds/settings etc. i know they have blower motor modules and that it grounds the blower motor....has anyone else had this problem? i dont know if the module is bad because its not grounding the blower motor or if the ground wire or connector its self is bad...im a jeep virgin so i dont know if this is a common problem
Mrd4322 is offline
post #2 of 2 Old 01-23-2008, 07:19 PM
Briandl
First make sure it's not this:
http://www.wjjeeps.com/blower_motor.htm
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
blower motor resistor problem? ababyboy4me1 ZJ Grand Cherokee Forum 0 10-08-2009 01:03 PM
Wired up blower motor power module - do I need to replace blower motor? sniperdude ZJ Grand Cherokee Forum 0 04-19-2009 02:33 PM
HELP! Blower Motor, Blower Motor Resistor Fix Already Attempted... No Luck! DJGWJ ZJ Grand Cherokee Forum 3 12-26-2008 12:51 PM
94 JGC, where is the blower motor relay, and where's the blower motor ground wire go? camosilver ZJ Grand Cherokee Forum 1 08-24-2006 10:15 PM
Blower motor noise - solved the problem today !!! rocou ZJ Grand Cherokee Forum 6 06-29-2005 08:31 AM
