Hella light Wiring?? - JeepForum.com
post #1 of 3 Old 07-21-2009, 09:54 AM Thread Starter
BLKSVT
Well i mounted some lights to the bumper this weekend....turned out really nice, the only problem now is I don't have them wired right, I followed what was some sorry *** wiring instructions I thought. It called for hooking a green wire into the headlights, well I didn't do this because I don't want them on with the head lights. I wired it back through the relay , then to the provide switch inside but no lights...Does anybody have any suggestions??
The lights had a black and blue wire, it appeared that the blacks got tied together and back to the relay, the blue wires appeared that they were to be grounded to the truck, there is a blue wire off the relay that appears to get grounded, then there is a yellow wire that runs back to the switch, then there is a fused green wire that I THOUGHT is an option to the head light??? and of course the red power wire to the battery...
Any help will be appreciated, I am really getting old...I used to be able to wire anything, now I can only pop beer tops and watch it seems..
BLKSVT is offline
post #2 of 3 Old 07-21-2009, 10:33 AM
StrokedWJ
StrokedWJ's Avatar
http://www.hella.com/produktion/Hell...ngDiagram1.pdf
The green wire is used as a switched 12v. When do you want the hellas to come on? If independent of the hi/low beams you can tap into the parking lamp. But personally I don't know why you'd need the hellas on without at least having the lows on.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 3 Old 07-21-2009, 04:47 PM Thread Starter
BLKSVT
So the green wire has to be utilized no matter what...that may be where I screwed up.
By the way thanks for your help..^^^^
BLKSVT is offline
Hella 500FFs w/ stock wiring UTChavok ZJ Grand Cherokee Forum 12 12-03-2008 08:04 AM
Hella 500 wiring problems!!! SouthernboyWJ ZJ Grand Cherokee Forum 8 03-29-2007 11:48 PM
Hella 500 Wiring help dturano547 ZJ Grand Cherokee Forum 23 10-22-2006 08:44 PM
Foglight wiring? Replacing with Hella. 7tiger7 ZJ Grand Cherokee Forum 10 05-04-2006 05:45 PM
I Need A HELLA 500 Wiring Diagram! GrandRubicon155 ZJ Grand Cherokee Forum 4 08-26-2004 03:44 PM
