Hella 500FFs w/ stock wiring - JeepForum.com
post #1 of 13 Old 12-02-2008, 08:26 PM Thread Starter
UTChavok
My stock fog lights on the bumper are trashed, one bulb is blown and the other got ripped off today. Im curious if id be able to hook up some Hella 500FFs on the stock wiring there and just use the fog lamp switch thats already there. I know the bulbs are 55W but I wasnt able to find what amp the fuse in the wiring kit is to see if it matches with the stock fuse.
-Ronnie
UTChavok is offline
post #2 of 13 Old 12-02-2008, 08:30 PM
StrokedWJ
StrokedWJ's Avatar
Shouldn't be a problem...I'm running 3 rock lights off of the stock fog light switch in my WJ.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 13 Old 12-02-2008, 08:33 PM
madrabbitt
madrabbitt's Avatar
its doable, the hellas are the same wattage as the stocks... however, the stock wiring is thin and crappy, and yours is probably old and rotted anyway.
I'd use the stock wiring as a relay trigger, and use the hella harness for the setup.
Ask me if you want me to expand on that.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #4 of 13 Old 12-02-2008, 08:34 PM Thread Starter
UTChavok
That would be great. Just got a check and was thinking about ordering these tommorow.
-Ronnie
UTChavok is offline
post #5 of 13 Old 12-02-2008, 08:40 PM
madrabbitt
madrabbitt's Avatar
wire up the harness from the battery to the light like the included instructions say, except for terminal 85
Run the positive wire from one of your existing fog lights to terminal 85. That way the stock switch triggers the new lights, but you have new wiring carrying the current.
Also, dont buy them from walmart, buy them from an auto parts store, or order them online.
The walmart ones, for whatever reason, have thinner cheaper harnesses.
post #6 of 13 Old 12-02-2008, 08:42 PM Thread Starter
UTChavok
Yeah Ive been looking for them online with a site with free shipping. Walmart here doesnt carry the FFs anyways.
Edit: im sitting here talking about it with someone, whats terminal 85? is that on the new wiring harness? I need to find a wiring diagram of the new lights.
-Ronnie
UTChavok is offline
post #7 of 13 Old 12-02-2008, 08:44 PM
madrabbitt
madrabbitt's Avatar
try amazon. i've ordered hella lights from there before.
post #8 of 13 Old 12-02-2008, 09:04 PM Thread Starter
UTChavok
Does anyone have any pics of the brackets theyve made or bought for the 96+ grands that dont have stock ones? Or should I just go to the yard and try to find some.
-Ronnie
UTChavok is offline
post #9 of 13 Old 12-02-2008, 09:09 PM
madrabbitt
madrabbitt's Avatar
look at the bottom of the relay (obviously, when you HAVE a relay in your possession)
The terminals are numbered
30 is supply
85 is trigger
86 is ground
87 is output
post #10 of 13 Old 12-02-2008, 09:10 PM
madrabbitt
madrabbitt's Avatar
dunno how much it helps, but:
Just happened to see what you needed in darthteddy's thread
post #11 of 13 Old 12-02-2008, 09:17 PM Thread Starter
UTChavok
Thats what id need. I think I may hit up a yard or two on thursday and look for some of those brackets.
-Ronnie
UTChavok is offline
post #12 of 13 Old 12-03-2008, 12:39 AM
Chris93zj
good luck getting them off...better bring some PB blaster and/or a torch to heat the bolt that holds them on. if, that is, you are in an area that sees any salt.
mine, after 3 years of being installed have completely corroded and even with an impact, all i can do is bend the brackets...
Chris93zj is offline
post #13 of 13 Old 12-03-2008, 09:04 AM
Clayton00grand
Walmart does carry them I bought a set there but just used the lights only. I definlately like the look of the FF vs, the standard ones.
Your PM's are full, clean out some so I can reply to your message.
Ken
Clayton00grand is offline
Hella light Wiring?? BLKSVT ZJ Grand Cherokee Forum 2 07-21-2009 05:47 PM
Can I wire my Hella 500's into my stock fog wiring? squashman702 ZJ Grand Cherokee Forum 11 02-15-2009 04:39 AM
Hella 500 wiring problems!!! SouthernboyWJ ZJ Grand Cherokee Forum 8 03-30-2007 12:48 AM
Hella 500 Wiring help dturano547 ZJ Grand Cherokee Forum 23 10-22-2006 09:44 PM
I Need A HELLA 500 Wiring Diagram! GrandRubicon155 ZJ Grand Cherokee Forum 4 08-26-2004 04:44 PM
