Hella 500 wiring problems!!! - JeepForum.com
post #1 of 9 Old 03-28-2007, 10:10 PM Thread Starter
SouthernboyWJ
so i bought some hella 500 driving lights and started to install them with a buddy of mine tonight.....it says on the directions to run a wire to the high beams but i am not sure which wire to cut for the high beams......im really pissed off about it cuz i had other things to do so can someone please tell me how to get to the high beam wire and what it looks like!!!!!????
SouthernboyWJ is offline
post #2 of 9 Old 03-29-2007, 08:13 AM
zaq123
zaq123's Avatar
1941 JK Wrangler
It's illegal to have fogs that come up with the high beams. Those instructions were written in China I bet. Hook it up to the low beams, or if you really want to use it with high, hook it up to the driving light (what's is illegal as well but it's up to you). Or even better, tap it into your OEM fogs WJ has 2 bulbs, one for high and one for low, so there shouldn't be a problem to figure out which one is which as long as you identify the ground wire(use multimiter to ring it for continuity to the ground).
No need to cut the wire eather, tap it right by the headlight using this tipe of connector.
zaq123 is offline
post #3 of 9 Old 03-29-2007, 08:23 AM
nierace
nierace's Avatar
2003 WJ
They're illegal for street use(Offroad driving lights)...so if a cop sees you with them on....
But as long as you're good about not leaving your high beams on...I would wire it to a switch though.
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #4 of 9 Old 03-29-2007, 08:31 AM
zaq123
zaq123's Avatar
1941 JK Wrangler
If you don't have a switch that came with your Hellas, wire them toy your OEM fogs, this way you can ON/OFF them as needed.
zaq123 is offline
post #5 of 9 Old 03-29-2007, 08:34 AM
nierace
nierace's Avatar
2003 WJ
Thats how mine are set...but I have fogs not driving lamps.
Nickerdoodle
35" BFGoodrich KM2
nierace is offline
post #6 of 9 Old 03-29-2007, 11:43 AM Thread Starter
SouthernboyWJ
well the thing is that the green wire thats supposed to go to the high beam is also supposed to attach to the back of the switch....my question is how can i go about disregarding the green wire and just having the lights to when i hit the switch the come on no matter what
post #7 of 9 Old 03-29-2007, 06:01 PM
donkie
Just rewire it using the switch and relay they provide, forget about the directions. You would want to turn these on whenever you want, right?
If you are not good with relays (meaning you have done this several times before without burning down your heep) just mount the lights and save yourself the trouble - find the nearest local car audio shop and they will do it for 20 bucks...
donkie is offline
post #8 of 9 Old 03-29-2007, 11:41 PM
j.love
j.love's Avatar
1994 ZJ
I have the same hella lights.. I cant remember rite off the top of my head with out going out there and looking at what I did but there was two diagrams in the instructions.. one shows how to attach it to the headlights and one with out the headlights.
I think if you just supply the switch with power from under the dash and then to the relay, that should do it
here are a few links....
http://www.jeepin.com/features/hella/index.asp
http://www.jeepforum.com/forum/f20/hooking-up-off-road-lights-393550/
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #9 of 9 Old 03-29-2007, 11:48 PM
madrabbitt
madrabbitt's Avatar
Instead of tapping the green wire to the high beams, feed that wire to the fusebox. find a fuse thats only on with the ignition, or use the IGN or AUX point if theres nothing there.
That'll give you what you want.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
Hella light Wiring?? BLKSVT ZJ Grand Cherokee Forum 2 07-21-2009 04:47 PM
Wiring Hella 500s on roof NickkciN ZJ Grand Cherokee Forum 19 01-08-2009 02:18 PM
Hella 500 Wiring help dturano547 ZJ Grand Cherokee Forum 23 10-22-2006 08:44 PM
Foglight wiring? Replacing with Hella. 7tiger7 ZJ Grand Cherokee Forum 10 05-04-2006 05:45 PM
I Need A HELLA 500 Wiring Diagram! GrandRubicon155 ZJ Grand Cherokee Forum 4 08-26-2004 03:44 PM
