Heavy Duty 42re - JeepForum.com
post #1 of 8 Old 08-29-2007, 10:19 AM Thread Starter
lucky_logger6
Heavy Duty 42re
Does anyone have experience with a high performance built 42re. I am in need or a rebuild but am disappointed that my factory built trany only lasting 85k and even when working well would “slide” in to gears rater than give nice firm shifts. Granted I don’t know the maintenance of the first 50k but it seems that the 42re is the week link in the drive train. This is going into a stock rig but It seems other stock jeeps are needing rebuilds around 100k as well, so I’m thinking I don’t want to be dumping another trany in it in 3yrs
I have had a local shop quote me around 2300 for a “full rebuild.” I then started looking around the net and found a few high performance builders building racing transmissions. Does any one have experience with either of these two builders?
http://www.apsprecision.com/
http://www.levelten.com/
Thanks for the feed back and other ideas.
lucky_logger6 is offline
post #2 of 8 Old 08-29-2007, 10:23 AM
ajmorell
ajmorell's Avatar
You don't need a high-performance rebuild, you just need to make sure that it get rebuilt with quality parts. There are really only a few parts that need to be upgraded in the trans to beef it up.
ajmorell is offline
post #3 of 8 Old 08-29-2007, 10:36 AM Thread Starter
lucky_logger6
Thanks for the quick reply. Can you explain what parts should be upgraded.
post #4 of 8 Old 08-29-2007, 11:49 AM
shadetree
I swamped my Jeep and I got water in the tranny and had the local aamco rebuilt it and for an extra $85 I bought an aftermarket shift kit and had them install it. Now it shifts better then new and the shifts are firm.
"If I can't buy it or borrow it, I don't need it"
-1994 ZJ Lifted and Locked...
-1983 CJ7 4.2ltr/Dana 300/Warn F&R bumpers...and some other goodies.
D.W.A. (Death Wobble Anonymous)
shadetree is offline
post #5 of 8 Old 08-29-2007, 12:10 PM Thread Starter
lucky_logger6
What did your rebuild run? Did they install the Transgo kit?
Thanks alot
post #6 of 8 Old 08-29-2007, 07:02 PM
Vestjam
Agreed.... add a shift kit with the rebuild. I checked locally before I did it myself and everyone was around $1200-1600 unless you pulled the tranny yourself. Then the price went to $850 range. Of course I'm hard headed, so when I did mine myself, I spent just under $450 with a new torque converter and shift kit.
I also bought a transmission specific manual that helped tremendously... It's faily straight forward. Take your time. You'll do great!
It's still running.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #7 of 8 Old 08-30-2007, 08:57 PM
Scottso699
2006 WK
I recently swamped my tranny too - it was like draining chocolate milk out of it when the pan came down - the tranny was rebuilt with Heavy duty bands and a shift kit. The also plugged the stupid breather behind the torque converter and plumbed one up on top. $2800 over all at Aamco - shifts like a mustang now - its pretty crazy! They also added a heavy duty tranny cooler.
Scott
2006 WK Overland, OME HD Springs F&R, Bilstein 4600 Struts, 1.5" Rear Spacer, 265/70/r17 BFGs
Scottso699 is offline
post #8 of 8 Old 08-31-2007, 06:27 AM Thread Starter
lucky_logger6
Thanks for all the feedback. Then jeep goes in for a tranny on Tuesday. I had local quotes from $1600-3000 with most shops wanting around $2000 for the rebuild. I was just thinking for a few hundred more I could get a custom built high performance built trany that should out last the jeep. I’m sure hopping the shop I chose does a better job than jeep did.
I asked about using a shift kit and they said it is part of their standard rebuild on a 42re
Who builds heavy duty 42re transmissions? drespecki ZJ Grand Cherokee Forum 1 12-20-2009 05:34 PM
heavy duty bumpers ... phitmein ZJ Grand Cherokee Forum 2 03-24-2009 09:59 PM
OME medium or heavy duty? drespecki ZJ Grand Cherokee Forum 5 12-03-2008 07:35 AM
Heavy Duty Tie Rod Replacement - Did you do it? IdahoZJGuy ZJ Grand Cherokee Forum 13 07-11-2007 01:37 PM
Heavy Duty Tie-Rods. Death-Mobile ZJ Grand Cherokee Forum 3 10-31-2004 07:34 PM
