Heater only shoots heat out of the defrost vents - JeepForum.com
post #1 of 24 Old 11-08-2008, 03:51 AM Thread Starter
hmmhoyhoy
My heater was working great but now it only shoots heat out of the defrost vents. Nothing comes out of the floor or the vents on the dash. I have no idea whats going on. I can flip through every setting and it always shoots out of the defrost vents. Any ideas.
94 ZJ 5.2
Thanks guys
95 YJ
4.0 AX-15
Dana 60 f with ARB 10.25 r and open. 5.13s
37" BFG AT's
02 WJ Overland
hmmhoyhoy is offline
post #2 of 24 Old 11-08-2008, 04:26 AM
10achik
I ate what?
10achik's Avatar
You have a disconnected or cracked vacuum hose under the hood, probably around the throttle body area. I'm betting your cruise control doesn't work either does it
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #3 of 24 Old 11-08-2008, 11:50 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I second that opinion.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #4 of 24 Old 11-08-2008, 06:19 PM
ChiSilverSupra
wow, i have that same problem. i'm gonna check it out tonight, all this time i thought that it was the selector.
ChiSilverSupra is offline
post #5 of 24 Old 11-08-2008, 06:57 PM
10achik
I ate what?
10achik's Avatar
I also read palms and and tell fortunes
Ken
2006 Pontiac G6 GTP
10achik is offline
post #6 of 24 Old 11-08-2008, 07:27 PM
mdav8629
One other place to check is look under the dash on the drivers side. If you look towards the glove box, there is a plastic white arm. It is right behind the message center. The lever breaks right by the eye that connects it to the shaft. If it is broken you will only get light defrost and heat. Just my 2 cents. Also there is an arm right under the ignition, try to push that up manually.
mdav8629 is offline
post #7 of 24 Old 11-09-2008, 04:08 PM Thread Starter
hmmhoyhoy
Good call, my cruise doesnt work and it stopped around the same time. I will check it out thanks guys
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
post #8 of 24 Old 11-09-2008, 04:21 PM Thread Starter
hmmhoyhoy
Do you have an idea of exactly which hose could be cracked? I'm looking at it and everything looks fine, so I'm not sure where to start looking. Thanks
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
post #9 of 24 Old 11-09-2008, 04:27 PM
EagleStorm
2008 WK
Could be your vacum source at the intake or by the vac canister. It defaults to defrost when there is a failure the fed's require it so alt least you can see out the windshield if there is a failure in your HVAC. ck the harness all the way from the manifold to the crusie and to the canister
EagleStorm is offline
post #10 of 24 Old 11-09-2008, 09:00 PM Thread Starter
hmmhoyhoy
Ok I have checked around for quite some time and am not finding anything broken or loose or cracked. I am not 100% sure what I am looking for though. Does anyone have anything specific as to what to look at, and a name for hose,vaccum line or whatever it may be?
Thanks for the help
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
post #11 of 24 Old 11-09-2008, 09:07 PM
magnumcherokee
1992 XJ Cherokee
Follow your vacuum lines to where they end,your going to follow one to a black round ball. This is your vacuum reserve, so that when you are on the throttle and vacuum is low, you do not lose your heat setting. there is a second vacuum line out of that to your firewall and into your dash selector. One of these two plastic lines is leaking. If you pull the one from the intake to the black reserve at the reserve end, and check for vacuum while the engine is running. If you can feel it suck to your finger, that vacuum is present, that line is good move to looking at the other one. If not, replace it with vacuum hose or find where its broken and splice it together with a piece of vacuum hose that fits TIGHTLY over the plastic line.
92 XJ sport 4.0L HO auto 231 Rustys 4.5"(gained 5") SA lift, ROR Adj TB, AR23 wheels, 33x12.50 MT Baja MTZs, doorless when sun shining
magnumcherokee is offline
post #12 of 24 Old 11-10-2008, 03:07 PM Thread Starter
hmmhoyhoy
Thanks I will check it out when I get home from work
95 YJ
4.0 AX-15
37" BFG AT's
02 WJ Overland
post #13 of 24 Old 01-25-2009, 02:36 PM
94SportJeep
TRY THIS
I had the same problem (Heat only blows throw Defrost setting), after checking everything, vacuum tubes, vent arms, switches, lines etc....
I finally randomly found the problem yesterday while doing an oil change. The vacuum line that runs under the hood located beside the battery. The line continues into the headlight bay. It was fully cracked just to the left of the battery. I replaced the broken portion of the line (1 inch) and everything works like new again.
94SportJeep is offline
post #14 of 24 Old 01-25-2009, 02:44 PM
10achik
I ate what?
10achik's Avatar
Originally Posted by 94SportJeep View Post
TRY THIS
Thats the vacuum line that runs to the reservoir, it's kind of the "end of the road" for the system, that section you're talking about is probably from the battery leaking at some point and dripping down on the line. Then again it could just be old. Good find though
Ken
2006 Pontiac G6 GTP
10achik is offline
post #15 of 24 Old 02-28-2009, 08:53 PM
Bmoore89
What does the cruise control have to do with the vacuum hose? I have both of these problems, but never thought that they could be related.
I'm pretty new to this whole Jeep/car repair thing, so dumbing it down would help.
Bmoore89 is offline
Vents will not switch. '04 WJ stuck on defrost. zj+3 ZJ Grand Cherokee Forum 25 11-15-2017 05:53 PM
No air coming from defrost vents D73 ZJ Grand Cherokee Forum 0 01-28-2010 08:09 AM
No Air from Defrost Vents D73 ZJ Grand Cherokee Forum 9 01-04-2010 01:11 PM
problems with air blowing only through my defrost vents joshhuwa ZJ Grand Cherokee Forum 1 07-19-2008 09:45 PM
Defrost not working, blowing out vents instead mattadams ZJ Grand Cherokee Forum 8 11-27-2006 01:52 PM
