Heater Core Problem - JeepForum.com
post #1 of 2 Old 11-08-2008, 07:44 PM Thread Starter
jtsjeep99
Heater Core Problem
My 99 WJ limited has recently started to smell like antifreeze when the heat is turned on. The windshield fogs up a little and then clears up and the antifreeze smell goes away after a couple of minutes. I'm pretty sure its the heater core. Does anyone know where to find a good write up on how to change it? I know its going to be a pain, but I have more time than money.
jtsjeep99 is offline
post #2 of 2 Old 11-08-2008, 08:51 PM
VulcanJeep
Pretty much the same procedure as replacing blend doors - remove the dash, completely! I've been led to believe that one should replace the evaporator core while you're in there, as they are flakey, too. I'd consider replacing the blend doors with aftermarket system if I had to pull the dash, as well.
VulcanJeep is offline
Heater Core pigpenn ZJ Grand Cherokee Forum 10 11-12-2009 08:35 PM
heater core beckysjeep ZJ Grand Cherokee Forum 2 03-14-2008 02:20 PM
New Heater Core...Still not hot EmpireTroy ZJ Grand Cherokee Forum 2 12-24-2006 04:01 PM
Heater core? 2002jeep ZJ Grand Cherokee Forum 3 10-26-2006 08:34 AM
ZJ heater core TonyTJ ZJ Grand Cherokee Forum 2 08-10-2002 12:22 PM
