Heater core. Finally rears it's ugly head... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Heater core. Finally rears it's ugly head...
Unread 10-08-2013, 10:37 AM   #1
KJK
That's great.
I've noticed a slight fogging of the windshield lately along with a wiff of anti-freeze. It appears that a new heater core is in my future. I've subscribed to the 32 steps to removing a ZJ dash thread.
I've read that some have had fitment issues with aftermarket heater cores and AC evaporators (I'm doing it all while I'm in there).
Does anyone that's done this have any input as to what aftermarket brands for sure fit without any major issues? I hate surprises.
I'm looking through Rockauto or any other places.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 10:40 AM   #2
V65Ozzie
Originally Posted by KJK View Post
That's great.
Take lots of pics, I'm going into mine this winter, specifically for the AC, but will put a new core in while I'm at it.
Retreat? Hell, we just got here......
V65Ozzie is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 11:09 AM   #3
Jeeples
Jeeples's Avatar
It's really not that bad, having never done a heater core and taking my time I ended up with about 6 hours total into mine. The only thing I didn't do was replace the evaporator, which I am kinda kicking myself for since I haven't haven't been able to pull a vacuum on my AC, so I suspect I have a leak somewhere. I did however replace the receiver drier.
I bought my heater core off Amazon:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
I had absolutely zero fitment issues and it dropped right in. It is important to note that on this unit the heater hose fittings swivel, allowing you to kind of 'fine tune' their fitment/placement through the firewall. I'm sure it also allows for easier packaging for the manufacturer as well.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Build Thread
Originally Posted by wjjeep19 View Post
It is what Jeeples has stated.
Jeeples is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 09:07 PM   #4
Rikoshay
How many miles???
Make sure you flush your coolant system and clean the ground wires!!!
Everybody knows that ZJ's have ground issues, but not a lot of people know that a faulty ground can lead to the starter using the cooling system for a ground path, which leads to blown heater cores.
Rikoshay is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 10:44 PM   #5
AVR2
On the 93-95 ZJs, there's no need to follow the complete FSM method for dash removal. The FSM procedure is about literally removing the entire dash from the vehicle, whereas for AC work you only need to remove enough to be able to pivot the passenger side of the dash far enough out to get at the AC box. This reduces the number of steps fairly significantly.
It may be worth Googling to see if you can find a writeup on the quicker method for the 96-98 dash. In fact I'm sure I've seen one somewhere. Here's the writeup for the 93-95, which demonstrates how much less work you need to do.
AVR2 is offline   Reply With Quote Quick reply to this message
Unread 10-08-2013, 11:09 PM   #6
xcaliber81
1994 ZJ
The dahs wonc come all the way out anyhow thanks to the wiring that is looped through the back side of the dash and you dont want to be removing all that cause you end up with a HUGE mess lol I know cause I just stripped a 93.
xcaliber81 is offline   Reply With Quote Quick reply to this message
Unread 10-09-2013, 10:03 AM   #7
KJK
Originally Posted by Rikoshay View Post
How many miles???
152,000.
I ordered the evap and heater core from Rockauto so we'll see.
I cut the hoses from the heater core and have them looped together temporarily. Good thing I'm in the south where it's very temperate this time of year.
I can evacuate the AC system with a recovery machine at work.
Do the aftermarket evaporators come with o-rings for the connections?
Unread 10-09-2013, 10:10 AM   #8
KJK
That's the write up I plan on using.
Can anyone confirm it works on a later ZJ (98)?
Unread 10-09-2013, 10:18 AM   #9
xcaliber81
1994 ZJ
Theres a write up for 96-98 floating around im positive ive seen it.
Unread 10-09-2013, 10:18 AM   #10
newfieZJ
never mind . can't delete post
newfieZJ is offline   Reply With Quote Quick reply to this message
Unread 10-09-2013, 12:26 PM   #11
KJK
That's the one I linked to in the first post.
Unread 10-09-2013, 04:41 PM   #12
bcbueller
removing the dash is a two step process on the 98 outer dash panels then the under skeleton that all the vents are connected to ,then the heater box can be removed . as well on the 98 there are several hidden nuts in the engine compartment and another under the pcm on the passenger side
Just a Bueller
bcbueller is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 11:14 PM   #13
CatSplat
1994 ZJ
For reference, this thread from the Dodge forums shows the two kinds of heater cores and has Spectra part numbers (Our GCs use the same core):
http://www.dodgeownerforums.com/smf/...?topic=17527.0
Apparently the swivel style is much easier to install than the rigid-line version if you're not removing the entire HVAC box as a unit.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline   Reply With Quote Quick reply to this message
Unread 10-11-2013, 05:32 AM   #14
coralman
its the beam Jim
coralman's Avatar
This is on my priorty lists as soon as my avatar can ok it,lol. I wonder why the swivel would be easier, cause you can rotate it? Another connection point would kinda give me the creeps on this particular repair. I have to replace all the foam on the doors anyway {tired of chunks blowing out all over the place} so I'll be pulling the whole housing.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is offline   Reply With Quote Quick reply to this message
Unread 10-11-2013, 08:14 AM   #15
zjosh93
Agreed about being leery of the swivel joints. When I did mine I searched until I found an aluminum non-swivel heater core just like the factory one I pulled out. Not sure where I found it but I think I got the last one they had. RockAuto only lists the aluminum swivel cores and the brass solid core now. The swivels are sealed with an o-ring and the fitting is crimped down to keep the whole thing together. I didn't want to add a couple of potential failure points under my dash.
On my 93 I took the whole dash out step by step following the Haynes manual. Took about 6 hours from start to finish. Not that bad a job actually; a lot of steps but nothing really hard about it.
zjosh93 is offline   Reply With Quote Quick reply to this message
