Heater control problem, help please! - JeepForum.com
post #1 of 15 Old 12-10-2007, 04:02 PM Thread Starter
Parsonsbri
Hi all, new to the forum here.
I own a 2001 Jeep GC and recently sold it to my Dad. It is in really great shape. Of course a month after I sell it to him, there is a problem.
What is happening is that the heat on the passenger side is not working, only "blowing cold" according to pops. On the driver side, no problem. On the passenger side the defrost vent, vents on the dash and the floor all blow cold.
He called a dealer in the small town where he lives and was told that a little plastic piece has a tendency to break and the only repair is to replace the whole control unit...wait for it...for $900, thank you.
Can anyone provide some insight? I would really like to know if anyone has either experienced this or knows a solution.
Thanks,
BP
Parsonsbri is offline
post #2 of 15 Old 12-10-2007, 04:05 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
blend door issue. very common. there's write-ups around here to help you do it yourself.
ratmonkey is offline
post #3 of 15 Old 12-10-2007, 04:07 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
I assume it's Limited. If so, this is your issue, or should I say your dad's issue
http://www.wjjeeps.com/hvac_sub_assembly.htm
zaq123 is offline
post #4 of 15 Old 12-10-2007, 04:10 PM
JG_Canuck
Kludge fix: search ebay for "heater treater"
JG_Canuck is offline
post #5 of 15 Old 12-10-2007, 04:36 PM Thread Starter
Parsonsbri
Thanks guys!
Is there any way to diagnose which of the two problems that are listed on the link without going in for service?
post #6 of 15 Old 12-10-2007, 06:27 PM
koegg58
I just had this done at the dealer and had them replace HVAC control box with redesigned unit so it should not happen again. While it's apart you should change out the evaporater and heater cores as well. I know this is expensive but thats the price of owning a Jeep.
koegg58 is offline
post #7 of 15 Old 12-10-2007, 06:37 PM
Briandl
Originally Posted by Parsonsbri
Thanks guys!
Run the test shown here:
http://www.wjjeeps.com/climate.htm
You can then post the codes here and we'll be able to give you more specific information about the problem and solution.
How many miles on the Jeep in question?
If you replace the evaporator core and heater core I've heard you should also replace the expansion valve.
2002 Jeep Grand Cherokee Limited 4.7L H.O. V8
Briandl is offline
post #8 of 15 Old 12-10-2007, 07:07 PM
alexo1us
Its your dad..
fix it right..
maybe he will pay for half since he owns it bbw here
the heater treater is great option but not the best
even if you go this route it will cost you ,more if someone else does the work,
new parts are better
good luck
Alex
08 Overland crd
5.9 Wrecked 12 24 07
My New Love Stolen /07/07
01 Grand limited 4.7V8/QD
SFN Silver on Grey
alexo1us is offline
post #9 of 15 Old 12-11-2007, 07:30 AM
WJChris
WJChris's Avatar
I just replaced my heater core (same amount of work) Only took 10 hours.
Stealership here wanted $1500!!
Get a manual and do it yourself!
WJChris is offline
post #10 of 15 Old 12-11-2007, 08:46 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Thanks guys!
You would still have to pull the dash, even if its a problem with the blend door actuator, because your problem is with the passenger side.
Wheelin98TJ is offline
post #11 of 15 Old 12-12-2007, 02:58 PM Thread Starter
Parsonsbri
Thanks guys.
The reason I am here is because $900-1500 is not in the budget. We have to do this ourselves if its going to happen. It looks like even the worst case would take a day at most to do it. both of us are fairly handy around a car. On my 98 limited I had the dash out once to do a stereo upgrade. It was scary the first time, but you just have to be patient and follow the instructions.
i am going to have dad run the diag and see what codes come up. I will report back once I get the codes.
post #12 of 15 Old 12-12-2007, 03:24 PM
JG_Canuck
The parts are not that expensive, and if you can spare the time it's easily a DIY job. There is a full writeup on www.wjjeeps.com and there is some valuable additional info here
post #13 of 15 Old 01-11-2008, 03:35 PM Thread Starter
Parsonsbri
Its been a while since I have been back, but all is well.
Ran the diag suggested by the dude at "Heater Treater". I was lucky since it was only the blend door and not the motor. Easy fix. Took us about an hour and a half. I could do it again in 30 minutes. Compared to the $1000 plus the dealer wanted, Dad is ecstatic and the heater is working perfectly.
Thanks for the tips gents!
post #14 of 15 Old 01-11-2008, 05:00 PM
daveyboy43
What test did he tell you to run?
daveyboy43 is offline
post #15 of 15 Old 01-11-2008, 07:41 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
here
http://cgi.ebay.com/ebaymotors/Jeep-...spagenameZWDVW
zaq123 is offline
heater A/C control flashing rapidrabbit ZJ Grand Cherokee Forum 0 12-12-2008 02:55 PM
Heater control problem 4.0 ZG 1996 jimjam515 ZJ Grand Cherokee Forum 0 08-22-2008 08:43 AM
Heater / AC Control 99' JGC codyman ZJ Grand Cherokee Forum 1 01-25-2006 07:47 PM
1998 JGC limited 5.9 dome lights and heater control lights problem zoom248 ZJ Grand Cherokee Forum 6 04-12-2004 05:02 PM
Heater Control Question boing ZJ Grand Cherokee Forum 2 06-17-2003 11:18 AM
