Heater/Aircon Airflow Problem - JeepForum.com
post #1 of 1 Old 07-05-2006, 05:33 PM Thread Starter
BOBBYBARLOW
Hello All
I posted a previous problem & got a response(Thanks!), but to be honest was not a 100% certain where to look, see below has any one else any more ideas or advice.
Thanks
I wonder if any one can help,On my 2001 4.0 G Cherokee the heaters/aircon fan works but there is allmost no air flow from any vents. This is not the dreaded "Blended Door" problem is it as the temperature on all vents seems the same
Do you have air flow from the defrosters or from the floor vents? It sounds like the diverter door is stuck, it works off of vacuum so you might want to check the vac lines in and around the engine compartment.
PS It does appear to be the top air vents only
BOBBYBARLOW is offline
Lights on front bumper... airflow problem? the88thpianoman ZJ Grand Cherokee Forum 34 12-22-2009 04:04 PM
Aircon heater problem. Works after ignition turned off/on. Magiciv ZJ Grand Cherokee Forum 0 11-12-2009 06:28 AM
Clunking sound from AirCon altugk ZJ Grand Cherokee Forum 12 10-29-2006 04:18 PM
airflow problem BOBBYBARLOW ZJ Grand Cherokee Forum 1 08-04-2006 10:07 AM
Stinky AirCon / Heater Brow ZJ Grand Cherokee Forum 10 06-07-2005 01:39 PM
