Heater/air control will not change vents - JeepForum.com
post #1 of 9 Old 06-30-2004, 07:08 PM Thread Starter
overseer
I have a 96 Jeep grand Cherokee. The heater is stuck on defrost all the time and I cannot switch to any other vent modes. (If I try to turn the air on from defost, nothing happens) Has anyone had this problem? If you have please help me. It is hot out and we and we are melting.
Thanks
overseer is offline
post #2 of 9 Old 06-30-2004, 07:19 PM
driabyor
driabyor's Avatar
1994 ZJ
a vacuum problem,, switch on dash ,, bad hose ,, bad vacuum motor... door stuck......
driabyor is offline
post #3 of 9 Old 06-30-2004, 07:23 PM
Dalmask
With a Haynes manual and a vacuum tester, you can at least eliminate a couple of the possibilities.
-Dal
Dalmask is offline
post #4 of 9 Old 06-30-2004, 07:47 PM
77'cj7
77'cj7's Avatar
Go to the stealership, they will sell you a little plastic part u have to splice into the system. It solves a vacuum problem, i think. Worked on dads 94 zj.
77'cj7 is offline
post #5 of 9 Old 07-02-2004, 09:38 AM Thread Starter
overseer
Thanks
I just wanted to say thanks for everyone's help and advice on this. I notice that alot of people do not take the time to do this. I will give these a try. If you guys run into trouble I will be there to help
overseer is offline
post #6 of 9 Old 07-02-2004, 03:14 PM Thread Starter
overseer
update
At looking at the Automatic climate control, I have also noticed that the little guy that shows you where the vent is supposed to go is missing no matter what vent you switch it to.
Does this give anyone any ideas??
overseer is offline
post #7 of 9 Old 07-02-2004, 03:23 PM
97grand
97grand's Avatar
Have you put the ATC head through the self-check mode? Here's the procedure. It's really easy to do...
With the Climate Control off, press both the AC and RECIRC buttons.
While holding them in, turn the temp knob one click clockwise.
The display will light up with all icons.
Release both the AC and RECIRC buttons, and then press one of them. Doesn't matter which.
A "driver" icon will show, with 2 digit codes listed, 00 being no fault.
A code of 25 or 29 is bad. New ATC head unit.
Mine was a 23, meaning a problem with the blend door actuater. That sucks. The whole dash has got to come out to access it. $$$$$$$!
97 Grand Cherokee LTD 5.2L V8. 130k Black on Black; Gold Trim
Only mod's are a toddler seat and a spilled juice cup! SOLD
'91 Taurus SHO+ - Deep Jewel Green
'05 Grand Caravan SXT Inferno Red
'69 Dodge Charger - Black primer
97grand is offline
post #8 of 9 Old 07-02-2004, 09:11 PM
10achik
I ate what?
10achik's Avatar
This same issue happened to me not long ago, and I had accidently disconnected a vaccum hose while changing the plugs. See if you can find any loose hoses dangling around. Be sure not to look between your legs J/k
Seriously thats what my problem was.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #9 of 9 Old 08-29-2004, 06:29 PM Thread Starter
overseer
Error codes - 40 and 51
I tried this out and got codes 40 and 51. Any ideas on what this means?
overseer is offline
Heater only shoots heat out of the defrost vents hmmhoyhoy ZJ Grand Cherokee Forum 23 04-08-2013 03:46 PM
Vents wont change hike4it ZJ Grand Cherokee Forum 2 07-02-2009 11:38 PM
Water from the rear heater vents (floor) Crit ZJ Grand Cherokee Forum 6 12-07-2007 05:58 AM
Water in heater/vents..kinda sound... Bliss Racing ZJ Grand Cherokee Forum 4 11-26-2006 07:49 PM
help!!! passanger side heater vents not as strop as driver side 2002jeep ZJ Grand Cherokee Forum 4 02-03-2005 10:13 AM
