Heater/ac controls not working - JeepForum.com
post #1 of 3 Old 05-01-2013, 04:40 PM Thread Starter
Chaoul1
I have a 1996 ZJ Limited, and now the heater controls don't function. The screen lights up, but the fan won't turn on or any of the controls. My buddy had a few minutes and checked the fan, and he said that fan works. He's thinking it's the controls or a fuse?
Any suggestions?
Chaoul1 is offline
post #2 of 3 Old 05-03-2013, 09:37 AM
KoreaZJ
1994 ZJ
1. Fuse #7 (40amp) located in PDC under the hood supplies power to Blower Motor.
2. Check the connectors on the front of the heater box for pin damage from overheating.
There are usually visual "burny marks and meltyness" (author: ratmonkey)
Looks something like this...
Some cut the connectors out and splice all the wires together.
Or just bypass the connector with damaged wires spliced together.
KoreaZJ is offline
post #3 of 3 Old 05-03-2013, 04:46 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I have often wondered when I see post like this if its the actual connector that is undersized in ampacity or other factors lead to this burnout. To me if the evap or heater core become clogged or even partially clogged would this not lead to a higher amp draw which with sustained use cook the connector? Even a filthy fan can significantly increase amp draw.
Originally Posted by HighLonesome
coralman is online now
