Heater, AC blower motor does not work on high? - JeepForum.com
post #1 of 3 Old 05-22-2016, 06:31 PM Thread Starter
Dean06919
1996 Jeep Grand Cherokee 4.0.
The heater motor no longer works on the highest setting. I put a volt meter on the connector, reading left to right and top down, #1 had NEGATIVE .30 volts, #2 had 13 volts, #3 had 1 volt, #4 and #5 had 13 volts. The two wires that exhibited less than 12 volts were dark green and black/brown.
Any idea if this indicates a broken wire or could the switch need replacing?
Dean06919 is offline
post #2 of 3 Old 05-22-2016, 06:59 PM Thread Starter
Dean06919
Update: I wiggled the wires by the blower motor, and it started to work. There's a lot of wires and connectors down there, any idea what one may be the problem?
post #3 of 3 Old 05-23-2016, 04:33 PM
kg6mov
Hears the voices
kg6mov's Avatar
Do you have auto climate or normal?
In the auto climate system there is a relay that controls high speed with the blower motor controller controlling the other speeds.
kg6mov is online now
