Heater - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Heater
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 01-10-2009, 05:40 AM   #1
essexkoi
Heater
hi all, I have a wj year 2000 its a 3.1td and i cannot seem to get the heater to blow hot the engine runs at about 70 . i have changed the thermostat and had all the pipes checked all ok . can you get a grille cover to limit the amount of wind getting to the radiator or any other ideas please. Its a bit cold for us here in the UK
essexkoi is offline   Reply With Quote
Unread 01-10-2009, 05:50 AM   #2
sandman
blend doors?
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Unread 01-10-2009, 05:53 AM   #3
jeepin161
if you did the thermostat yourself... i'd start by attempting to bleed the coolant system. its also possible you were sold the wrong thermostat. does it overheat @ all? if so... overheating and no heat can sometimes mean the tstat is in backwards.
jeepin161 is offline   Reply With Quote
Unread 11-20-2009, 12:34 PM   #4
chico
iv also got a 3.1 td mines gets warm but not hot and it takes a while for it to do so any ideas as to wot the problem is when i put the temp setting on high it blows cold and when its on low it blows warm ?
chico is offline   Reply With Quote
Unread 11-20-2009, 12:52 PM   #5
ZJPunk98
Addicted to my Jeep
ZJPunk98's Avatar
as stated, check for air in the lines. if you hear bubbling noises, this could be a sign of air in the lines. Also as stated, this could be a damaged blend door issue. Just search blend doors and you will find tons of posts on here about how to diagnose it and fix it.
As for a wind skirt for the front. Go to your local hardware store and by some screw snaps and the associated caps that go with them. Purchase some tough material, cut to size for the grill. Might have to stitch or melt the edges of the material to keep in from freying.
Next screw the snaps into place on the grill, line your material up with the snaps and install the caps. this will allow you to install or remove the grill cover easily. I have pictures of this somewhere. I did it to my mercedes when i was in ND where it is -40 during the winter
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote
