heater - JeepForum.com
post #1 of 5 Old 09-07-2013, 08:15 PM Thread Starter
bear1960
heater
My heater was working great but now it only shoots heat out of the defrost vents. Nothing comes out of the floor or the vents on the dash. I have no idea whats going on. I can flip through every setting and it always shoots out of the defrost vents. Any ideas.
bear1960 is offline
post #2 of 5 Old 09-07-2013, 08:31 PM
hpservertech
1994 ZJ
Had the same problem. Replaced the temp control and problem was solved. It is either that or you have a vacuum leak.
hpservertech is offline
post #3 of 5 Old 09-07-2013, 09:33 PM
JasonStebbins
Do you have digital or analog climate control?
Most likely a vacuum leak under the hood. Especially check the "T" near the firewall.
Poop
JasonStebbins is offline
post #4 of 5 Old 09-13-2013, 07:30 PM Thread Starter
bear1960
vacuum leak near firewall plastic tube broken now switches from dash or heat to defrost under power acceleration then back when let off gas
bear1960 is offline
post #5 of 5 Old 09-15-2013, 08:08 AM
congerz83
Same problem and solutions found here
http://www.jeepforum.com/forum/f13/h...ation-1458659/
congerz83 is offline
