heated seats - -- - JeepForum.com
post #1 of 8 Old 10-23-2009, 06:05 PM Thread Starter
netmonky
heated seats - --
Hi guys,
Quick question to you helpful chaps :-D.
I have a 1999 Grand Cherokee with a drivers seat that fails to heat :-(. Reading the web I can see that they made some great improvements in 2000-2004 models which do not stop working ...even if a wire breaks.
Question... if I get one of these seats - will it be compatible with the 1999 wire loom/plugs? I would think so as I cannot see them changing a great deal as itís the same shape etc
netmonky is offline
post #2 of 8 Old 10-24-2009, 12:16 PM
nick62087
I can't imagine they'd be different. Check out wjjeeps.com, they might have more info. Even if they are, you could probably figure something out to make it work.
Also, i found that bouncing up and down in the seat pretty hard sometimes makes the heat work on my 99. Just don't do it at a crowded intersection or you'll probably get some really strange looks if anyone notices. Also, i wouldn't recommend doing this while driving, due to the potential to lose control of the vehicle. Actually, when i think about it, a seat swap would probably be the better choice either way. Refer to the first 3 sentences above^.
nick62087 is offline
post #3 of 8 Old 10-24-2009, 02:26 PM
Turbonut
They are the same junk. Our old '01 had the heaters go so I replaced them with aftermarket units. The OE replacements for the Jeep is $329 list per seat.
Turbonut is offline
post #4 of 8 Old 10-24-2009, 02:41 PM Thread Starter
netmonky
hahah thanks nick62087.
Turbonut what aftermarket units did you buy ... could you wire them up to original switch?
netmonky is offline
post #5 of 8 Old 10-24-2009, 07:41 PM
Turbonut
I purchased a "large" set off eBay, 3 year warranty, then I cut the length to fit. No, you can't use the OE switch, but here's what I did. After removing the switch from the dash, I removed the entire switch (guts) from the housing, then cut plastic that fit perfectly inside the housing and attached with JB Weld, then drilled a hole in the center to accept the aftermarket switches, sprayed trim black, and reinstalled into the factory location. For wiring I ran a fused wire from the battery into a relay that was activated by a wire to the lighter then ran the wiring to the switches, then with the console removed, wiring down the hump, under the carpet and to the wiring under the seats. It was 3 years ago, so hope that's enough information. They worked great, but have since sold the Jeep.
Turbonut is offline
post #6 of 8 Old 10-25-2009, 11:56 PM Thread Starter
netmonky
thanks ... i will keep that inmind :-D
netmonky is offline
post #7 of 8 Old 10-26-2009, 12:06 AM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
why cant you use the stock switches? higher draw from the aftermarkets? if so why not run it through a relay?
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #8 of 8 Old 10-26-2009, 05:20 AM
Turbonut
Let's put it this way, the two three-position rocker-type switches, one switch for each front seat, provide a resistor multiplexed signal to the Body Control Module (BCM) through separate hard wired circuits. It didn't seem as though the OE switch controlled the power directly, rather the HSM or MHSM responds to the heated seat switch status messages by controlling the output to the seat heater elements of the selected seat. I just didn't want to bother experiementing with the OE switches, and the switch modification using the aftermarket switches took a minumum amout of time, as I did the switches before starting on the pad replacements.
If you decide to install an aftermarket pad, and have time, give the switches a try and see if they can be used, but also check over on wjjeeps for additional information:
Jeep Grand Cherokee WJ - Power and heated seats
Turbonut is offline
Installing heated seats into non heated wj Deah7 ZJ Grand Cherokee Forum 23 10-12-2012 02:08 PM
Installing 98 ZJ heated seats in a 93 with no power seats aaron7 ZJ Grand Cherokee Forum 4 12-28-2008 11:47 AM
heated seats jeeporvis ZJ Grand Cherokee Forum 2 04-19-2008 05:34 AM
need some help with my heated seats Semper Fi 03 ZJ Grand Cherokee Forum 5 03-04-2007 04:12 PM
Heated Seats Gone Redsand ZJ Grand Cherokee Forum 21 09-30-2005 07:54 PM
