Heated Seats - JeepForum.com
post #1 of 6 Old 11-12-2014, 07:22 PM Thread Starter
mjonesjr
Heated Seats
In my 9'er the heated seats are not working. I have fixed the outer wires on the driver side seat without any luck.
Would it be possible to use the factory switch to power an aftermarket heated seat pad?
'98 5.9 Limited
'99 4.0 Limited
mjonesjr is offline
post #2 of 6 Old 11-14-2014, 05:59 AM
Taz360ZJ
1994 ZJ
is the heated seat relay working?
'94 ZJ, AX15, UC+BB, Ravine's, 31's, 3.8L fan, D2S's, fully murdered out.
Taz360ZJ is offline
post #3 of 6 Old 11-14-2014, 06:05 AM
jb1331
Are the nerves in your backside shorted?
jb1331 is offline
post #4 of 6 Old 11-14-2014, 07:37 AM Thread Starter
mjonesjr
I've moved the relay from the passenger seat (which will click when turning on) to the driver side and it will not click when turning the switch on.
I've got good connection through the seat element, verified at the relay.
Nope, I can feel the heated seats in my Duramax and the wife's WJ.
'98 5.9 Limited
'99 4.0 Limited
mjonesjr is offline
post #5 of 6 Old 11-14-2014, 06:46 PM
Taz360ZJ
1994 ZJ
bad switch pod?
Taz360ZJ is offline
post #6 of 6 Old 11-14-2014, 07:10 PM Thread Starter
mjonesjr
No, switch pod checked fine. It outputs the proper voltage to the HSCM.
I do believe that the seat switch puts out 12v to the HSCM instead of the 5v that I had read. I'm going to do more investigating on it Sunday when I get off shift. If that is the case, I'm going to try to install the aftermarket seat heaters.
'98 5.9 Limited
'99 4.0 Limited
mjonesjr is offline
