Heated Mirror - JeepForum.com
post #1 of 9 Old 10-30-2009, 08:50 AM Thread Starter
muzak_mike
Heated Mirror
Hey guys,
does anyone have any diagrams or procedures for heated mirror removal / tear down?
Thx
Mike
2004 Grand Cherokee Overland
4.7L V8 HO
265 hp
325 ft/lbs
muzak_mike is offline
post #2 of 9 Old 10-30-2009, 09:12 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Remove the door panel and you'll see the 3 bolts that hold the mirror to the door.
Wheelin98TJ is offline
post #3 of 9 Old 10-30-2009, 09:17 AM Thread Starter
muzak_mike
thx
i should have stated my problem
mirror does not always go to the position set by the "memory" positions (Dirty Position Sensor Contacts?)
and heater element not working
both occuring on drivers side mirror
i'd like to get in and see about fixin in myself, how do i get right into all the guts of the mirror?
4.7L V8 HO
265 hp
325 ft/lbs
post #4 of 9 Old 10-30-2009, 09:21 AM
Wheelin98TJ
JEEP FREAK
I'd start with the wiring before tearing in to the mirror.
Sorry, I'm not sure if you can open those mirrors up or not. I'd guess they are an assembly that is sealed, but I've never looked at one close enough to know for sure.
post #5 of 9 Old 11-04-2009, 05:45 AM Thread Starter
muzak_mike
okie, will check out the wiring
found some good stuff on wjjeeps
replacement mirror assembly = $450 =
4.7L V8 HO
265 hp
325 ft/lbs
post #6 of 9 Old 11-04-2009, 05:52 AM Thread Starter
muzak_mike
some info for yourself
link --> Jeep Grand Cherokee WJ - Mirrors
thanks again!
4.7L V8 HO
265 hp
325 ft/lbs
post #7 of 9 Old 11-04-2009, 04:44 PM
gcjeeping
gcjeeping's Avatar
Check local junk yards. I got a pair of heated mirrors off an 04 from a pick n pull for 28 bucks for the pair.
gcjeeping is offline
post #8 of 9 Old 11-04-2009, 05:03 PM
dgejeep
I learned the hard way on how to get the glass off. Luckily I already had purchased a pair off a junker. The glass has attached clips that clip into the face of the adjuster motor (for lack of a better term).
http://www.wjjeeps.com/mirror_left_5.jpg (link to image of face of adjuster motor on site muzak posted)
http://www.wjjeeps.com/mirror_left_3.jpg (link to glass)
To remove the glass, push the bottom of the mirror in (which inturns pushes the top out) and then "slide" the glass upwards. When I broke mine apart I found that at manufacturing they actually stick a little glue in there for good keeping. I literally had to use a flat bar and pry pretty hard for it to pop out.
If the glass is out you set the glass with attached clips into openings and then you just slide the glass down which locks the clips in place.
dgejeep is offline
post #9 of 9 Old 11-05-2009, 12:18 PM Thread Starter
muzak_mike
Thanks a bunch guys!.....better be safe and try and find a replacement mirror before i tackle this...the scrap yard probably has no clue how much these mirrors are worth! haha....15$ would be nice!
since its 2 degrees out and snow was flyin today i probably wont get around to doin it this year.
looks like i'll be sraping that mirror this winter!
4.7L V8 HO
265 hp
325 ft/lbs
WJ Heated Seat problem and Mirror Problem JeepPleasure ZJ Grand Cherokee Forum 3 04-10-2008 02:00 AM
heated mirror cheif ZJ Grand Cherokee Forum 4 12-14-2007 12:01 PM
heated side mirror .. problem .. what to look for sanboy ZJ Grand Cherokee Forum 3 12-03-2006 04:16 PM
Heated Mirror Question> bikemanj7 ZJ Grand Cherokee Forum 3 03-28-2006 12:47 PM
Heated Side Mirror Question VinceV ZJ Grand Cherokee Forum 1 01-14-2003 10:54 AM
