heated mirror - JeepForum.com
post #1 of 5 Old 12-14-2007, 07:57 AM Thread Starter
cheif
heated mirror
got some snow and ice yesterday and discovered that the defroster on my drivers side mirror doesn't work. any one have a similar problem? anything to fix, or is it just time to buy a new one? (2004 GC) thanks
cheif is offline
post #2 of 5 Old 12-14-2007, 08:52 AM
LJS8510
LJS8510's Avatar
2015 WK
check fuse!
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #3 of 5 Old 12-14-2007, 09:04 AM Thread Starter
cheif
mirror defrost
The mirror has power to it because i can adjust it with the inside control, but it won't defrost. Are there seperate fuses for the same mirror?
cheif is offline
post #4 of 5 Old 12-14-2007, 10:22 AM
jeepgaffer
2006 WK
There are separate fuses for the mirror motors and the mirror heaters, but I'm fairly certain that both mirror heaters are on the same fuse. So, if the passenger heater is still working, that would make me think that it is not the fuse, but it is worth a look. Otherwise, I'm not sure what would be the cause other than malfunction/failure. I believe that you can replace just the mirror glass with a new one with the heating element, which would be less expensive than a whole new mirror.
Incidentally, since you have a 2004 model, you may want to direct your question to the "WJ" forum since it covers the year that you have (1999-2004).
Good luck!
2006 Bright Silver Grand Cherokee Laredo
3.7L 4WD ("mostly" stock)
jeepgaffer is offline
post #5 of 5 Old 12-14-2007, 12:01 PM Thread Starter
cheif
heated mirror
thanks for the help will check for voltage and go from there
cheif is offline
Heated Mirror muzak_mike ZJ Grand Cherokee Forum 8 11-05-2009 12:18 PM
WJ Heated Seat problem and Mirror Problem JeepPleasure ZJ Grand Cherokee Forum 3 04-10-2008 02:00 AM
heated side mirror .. problem .. what to look for sanboy ZJ Grand Cherokee Forum 3 12-03-2006 04:16 PM
Heated Mirror Question> bikemanj7 ZJ Grand Cherokee Forum 3 03-28-2006 12:47 PM
Heated Side Mirror Question VinceV ZJ Grand Cherokee Forum 1 01-14-2003 10:54 AM
