Heat only coming out of defroster vents - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Heat only coming out of defroster vents
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 01-23-2009, 02:44 PM   #1
thirteen
Regardless of the setting, heat will only come out of the defroster vent locations, not the dash vents or the lower vents.
Seems the controller that redirects the air must be bad... is it easily accessible? Is there anything in particular I should be looking for or aware of?
thirteen is offline   Reply With Quote
Unread 01-23-2009, 02:50 PM   #2
jetguy81
Look under the hood for loose vacum line, that happened to me once. I'm not with my jep at the moment, so I cant be more descriptive but it was very obvious on mine.
Big VA!
jetguy81 is offline   Reply With Quote
Unread 01-23-2009, 07:41 PM   #3
kmb0427
does your cruise control work?
kmb0427 is offline   Reply With Quote
Unread 01-24-2009, 07:09 AM   #4
mdav8629
limited or laredo. digital display? two different heat setups available. laredo will probably be hard plastic vacuum line if your cruise doesn't work, limited blend doors???
mdav8629 is offline   Reply With Quote
Unread 01-24-2009, 07:36 AM   #5
cmonson
this is NOT blend doors. This is a vacumn line. When you lose vacumn the selection defaults to the defroster setting for safety reasons. Typically I believe they fail by the battery. I would just closely follow each vacumn line and look for a split or tear.
cmonson is offline   Reply With Quote
Unread 01-24-2009, 09:41 AM   #6
thirteen
Haven't used it. Is this related to vacuum as well?
And for those that asked it's a Limited (orvis)
Unread 01-24-2009, 10:44 AM   #7
cmonson
Just do a search for defroster only, and some posts will come up. Look at the fittings by the firewall, and under the battery tray. I am willing to bet this is a vacumn issue and is an easy fix.
Unread 01-24-2009, 10:55 AM   #8
04WJGuy
Mine did the exact same thing 2 years ago, was a small crack in the vaccum line. Once it was fixed I haven't had any problems since.
04WJGuy is offline   Reply With Quote
Unread 01-24-2009, 12:27 PM   #9
kmb0427
Well, I have the same problem with my 2000 and i also have no cruise control and then i got on here a bit and found out that people were having the defrost problem along with no cruise control. My dad and i could find no vacuum leaks either. so he detached the vacuum line from the cruise control module and held it down with his finger and all my vents worked fine. so we're guessing it has to be a leak in the cruise control module. we're gonna look more into this week.
Unread 01-24-2009, 01:14 PM   #10
thirteen
Thanks for the tip, I'll try that as well.
Unread 01-26-2009, 07:10 AM   #11
thirteen
Ok, I can confirm that my cruise control DOES work. I did take a cursory look at the vacuum lines anyway and everything appears normal. What else should I check.
Unread 01-26-2009, 07:23 AM   #12
Kruzin
Could still be a vac leak.
My cruise works...to a point...But going up hills, it will not accelerate enough to downshift when it needs to (not enough vac to pull the accelerator all the way down, already tried replacing cruise actuator).
My heater will only blow out the defrost.
I know it's a vac leak, but just been too lazy to track it down.
It could also possibly be the vac actuator on the heater box under the dash is bad.
DD: 98 ZJ Laredo 5.2, all stock
Wheeler/Beater: 93 ZJ Laredo
4.0, AW4, 231 conversion from 249
3" coil lift, JKS Adjustable Track Bar, JKS Quicker Discos, KOR lwr rad supt, Brush guard
Colorado Jeep Club Member 242 (4.0L)
Kruzin is offline   Reply With Quote
Unread 01-26-2009, 08:30 AM   #13
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
As mentioned above multiple times, its a vacuum issue.
I have one vacuum line that likes to pop off of the intake from time to time even with a hose clamp. The heater will then switch to its default mode which is the defrost/floor setting, and you will loose cruise control function.
So check your vacuum lines for loose connections or leaks!
WALTER
walter_da_jpr is offline   Reply With Quote
Unread 01-26-2009, 08:42 AM   #14
djannello
In my 95 it wasn't a vacuum issue, but an issue with a little redirector door in the airbox itself under the dash. I've yet to fix it, but there was thread on here a while back that showed where you could push with a screwdriver or other implement (I used a ruler) once you set it to like face and it will stay there. I believe mine is caused by a broken piece of plastic inside the box itself, but haven't cared enough to actually pull the dash apart and try to fix it. Hope this helps.
djannello is offline   Reply With Quote
