Headliner - JeepForum.com
post #1 of 15 Old 05-12-2013, 10:23 AM Thread Starter
gingerbreadman1
Headliner
I want to re upholster my headliner. i want to do realtree AP camo. now ive never done this before. i dont know whats the best type of glue or fabric. http://www.joann.com/realtree-ap-twi...prd_01237056a/ this is 100% cotton so i didnt know if thats a good idea. http://www.lurasfabricshop.com/camo3...hed-twill.html this is a cotton denim i didnt know if this would be too heavy. if you know of any other fabrics that are better please send me the link. also please let me know what the best type of glue is. i want to get this done asap. thank you
gingerbreadman1 is offline
post #2 of 15 Old 05-12-2013, 11:39 AM
NYCXJ90
NYCXJ90's Avatar
2014 JK Wrangler
I did a cotton backed vinyl on my xj about 7 years ago. it was a lot heavier than the stock fabric. I used 3M vinyl top adhesive (like 3m 8090). Still holding it up there.
Go with the thicker material, it will be less likely to bleed through the fabric.
'90 XJ Laredo RE 3.5" Super Ride
'95 ZJ 5.9 Stock
NYPD Jeep Club Member #2
Marine Corps Jeep Club Member #3
So I tell the swampdonkey to sock it before I give her a trunky in the tradesman's entrance and I have her lick me yardballs.
NYCXJ90 is offline
post #3 of 15 Old 05-12-2013, 01:38 PM
x1n54n3x
I also need to do my headliner (pup took it down) but I was wondering if you have the dimensions needed or if you were just going to measure as you went?
x1n54n3x is offline
post #4 of 15 Old 05-12-2013, 04:52 PM
jt_armstrong
1994 ZJ
I did my headliner a few weeks back using one from WWW.wlsheadliners.com. mine has worked spectacularly well and so I ordered another one for my XJ. The material isn't like anything I could find in any of the local fabric shops. I ordered the upgrade on the adhesive just to be sure as temps here get real hot and will test most adhesives. All I paid around $100 and it took less that 3 hours from start to finish.
jt_armstrong is offline
post #5 of 15 Old 05-13-2013, 05:50 AM
KoreaZJ
1994 ZJ
Originally Posted by jt_armstrong View Post
...less that 3 hours from start to finish.
Great color selection.
How long does it take for the glue to set before it can be put back together?
Care to post a couple of pics of yours that shows the material?
KoreaZJ is offline
post #6 of 15 Old 05-14-2013, 06:06 AM
lawsonej
headliner replace
I did what alot of people did on here and took mine off, tore off material, sanded off foam, and rubber coated then truck bed linered the pad. So far it has worked good.
lawsonej is offline
post #7 of 15 Old 05-14-2013, 08:08 AM
Kingr98
2016 JK Wrangler
JoAnn's Fabric also sells foam backed headliner material. It took three yards (60" width) to cover the entire headliner and I bought an extra yard to make sure that I had enough for my sunvisors and sunroof shade but ended up with lots of extra. They had different colors of gray and tan that would match most Jeeps. I think that it was on sale for $10.99/yard. I used the 3M spray adhesive which is made for headliners that I got at Advanced Auto. It is not very difficult and there are plenty of videos on Youtube that show how to do it. Total cost was around $75 and it looks great.
Kingr98 is offline
post #8 of 15 Old 05-14-2013, 09:09 AM
jt_armstrong
1994 ZJ
The stuff I used is backed with a rough looking foam. I tried to upload some photos but it says my file sizes are to big and I ain't sure how to reduce them. I can pm them if you like. The glue is dried pretty quick. I had a beer between finishing the gluing and starting the installation.
post #9 of 15 Old 06-01-2013, 07:37 AM Thread Starter
gingerbreadman1
Worked out great. I used fabric from real tree.com and a spray adhesive. It looks awesome. And I didn't the overhead console trim as well... not the visors tho
post #10 of 15 Old 06-01-2013, 07:47 AM
KyBoy1991
This is what I'm wanting to do...
So you rubber coated it first??? I would have thought any of the truck bed liners would be all that's used. What's the reason to rubber coat it first?
KyBoy1991 is offline
post #11 of 15 Old 06-01-2013, 08:22 AM
monkeyhouse
Great thread. This is something I really want to do, but I figured it would be pretty hard. Sounds like I'm wrong there.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #12 of 15 Old 06-04-2013, 08:59 AM
lawsonej
I rubber coated it for three reasons, 1) i thought i would help isolate sound (wouldnt know if it actually did) 2) thought it would better cover fiberglass strands. 3 Rubber coating is cheaper than a can of nice bed liner. Overall, i dont see it as necessary for the finished project. Your perfectly fine skipping the rubber coating, it just saved my like 7 bucks for about the same finished project. Good luck
lawsonej is offline
post #13 of 15 Old 06-04-2013, 02:19 PM
KyBoy1991
This is going to be a late summer/fall project for me.
What did you do about the visors? And do you have a sunroof? If so, how'd you do the lining on the part that slides on the sunroof?
Also, have you noticed any sagging because of weight???
post #14 of 15 Old 06-04-2013, 05:53 PM
SCZJ
1994 ZJ
Great write-up right here: http://www.jeepforum.com/forum/f13/h...guide-1416673/
About to attempt this myself and want to use a different design as well.
'94 ZJ, 4.0, D30/D44A, 4 1/2" lift, 32" tires, 3.73 gears, etc... Just another cookie cutter ZJ.
SCZJ is offline
post #15 of 15 Old 06-04-2013, 06:25 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
gotta do this soon, windows down summer driving is not good on my saggy headliner
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
95 zj , headliner , upholstery
