Headlights are out - JeepForum.com
post #1 of 2 Old 08-21-2002, 10:59 PM Thread Starter
Paul's GCL
Headlights are out
The Lo-beams just went out on my Jeep. Hi-beams work. I checked all fuses (even though there don't appear to be any for the headlights) bulbs check out. I get 12 Volts on the hi-beam terminal that plugs onto the headlight (red/orange wire) when the highbeams are turned on and 0 Volts on the lo-beam terminal (violet/orange wire) when the lo-beams are turned on. Where is the hi/lo beam relay located (it's called a Headlamp Dimmer Switch in the Haynes manual)? Any help would be greatly appreciated as I'm afraid of the dark.
Paul
'96 GC Laredo, 5.2L
Paul's GCL is offline
post #2 of 2 Old 08-23-2002, 03:15 PM Thread Starter
Paul's GCL
Figured it out. You need a T20 Torx (the anti-tamper kind for some strange reason) to remove the steering column cover and headlight dimmer switch. The Headlight Dimmer Switch is located on the opposite side of the ignition key. The wiper/ emergency flasher/ blinker/ hi/lo beam switch contacts are all located in this single module. I disconnected the wiring and cleaned all of the oil from the contacts and re-assembeled. Lo-beams are now working. Hope this helps!
Paul
'96 GC Laredo, 5.2L
ZJ headlights.... JesseOR ZJ Grand Cherokee Forum 3 11-21-2009 07:12 AM
New headlights... Ds4x4 ZJ Grand Cherokee Forum 5 02-24-2007 02:14 PM
Headlights lorrick ZJ Grand Cherokee Forum 5 04-30-2006 08:30 AM
ZJ headlights TJRubicon06 ZJ Grand Cherokee Forum 24 11-10-2005 11:19 AM
New WJ headlights freeswimmingfis ZJ Grand Cherokee Forum 4 01-15-2005 03:29 PM
