Headlights Freaking Out - JeepForum.com
post #1 of 8 Old 11-14-2005, 11:44 AM Thread Starter
BlackBlt3D
Every once in a while when I have my headlights set to automatic on my '98 Grand, they will just start flashing on and off very rapidly. It started out very rarely, now it does it quit often. Is this the switch itrself or is there a sensor somewhere on it?
BlackBlt3D is offline
post #2 of 8 Old 11-19-2005, 03:58 AM
nosewitdot
hmmm... very odd....the same goes for my 99 WJ...i don't know why it does it either...i just worry that the guy in front of me is pissed off cuz he thinks i'm high beaming him
nosewitdot is offline
post #3 of 8 Old 11-19-2005, 07:38 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
The headlight sensor is on the dash (for the ZJ) in front of the driver. It also includes a blinky red light for the security system. So the sensor may be going bad, or maybe clear off the accumulated wrappers and coffee cups.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #4 of 8 Old 11-19-2005, 11:15 AM
zjeepin
zjeepin's Avatar
Just had this problem with my ZJ. Except my dashlights would flash, but the headlights started to as well. Brought to the stealership, and the Headlight switch was bad. Just a forewarning that the part is about $180. And my advice is install it yourself, easy to do if you can pop the dash off, don't pay them $120 to install it.
97 ZJ Chop Top-Buggy 5.2L V8, 249 T-Case
5" Lift, JKS Front and Rear Adj. Trackbars, RE Twin Tube Shocks, RE T-Case Drop, Cut Fenders, Chop Top, Half Doors.
33"x13"x16" Super Swamper TSLs on Black Steelies
Custom Rack, 4 Roof Lights, Roof Back-up Lights
zjeepin is offline
post #5 of 8 Old 11-19-2005, 12:00 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
I thought maybe your Jeeps used to be used by the police force so they had flashers installed.
It's probably the switch. If it works fine with the exception of the auto position, I would just not use the auto position. The cost of the switch is such that it is not worth it.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #6 of 8 Old 11-19-2005, 12:49 PM
Arkansas_WJ
Arkansas_WJ's Avatar
On my wj the auto mode is crap! It is on all the time despite if its dark or light.
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
post #7 of 8 Old 11-19-2005, 01:24 PM
ZJ_COWBOY
ZJ_COWBOY's Avatar
1994 ZJ
Your problem may not be the switch but the photo-sensor. Find were it located on your Jeep (on the dash by the defroster vents) and see if its been un-mounted, or fell into the vents to far down.
RIP 93' ZJ
RIP 98' Dodge Neon
2001 Neon getting 30 MPG w00t!
94 ZJ $200 Project.
ZJ_COWBOY is offline
post #8 of 8 Old 11-19-2005, 02:07 PM
Arkansas_WJ
Ill be sure to take a look at that tomarrow when i have that hood thing off to replace my tweeters.
Mitch
AIR BAG light freaking me out!!! nelson1248 ZJ Grand Cherokee Forum 4 05-26-2009 12:00 AM
Heater freaking out on me dcvance87 ZJ Grand Cherokee Forum 1 03-19-2009 08:37 PM
Freaking Lug Nuts! JrMechanic ZJ Grand Cherokee Forum 45 03-09-2009 09:19 PM
GSW DW Freaking out etc... ArloGuthroJeep ZJ Grand Cherokee Forum 28 06-06-2006 10:56 PM
Some of these threads are freaking me out AZ2004WJ ZJ Grand Cherokee Forum 26 06-01-2006 08:26 PM
